Ga door naar hoofdinhoud
Sony WH-1000XM5 Battery Replacement
Wat je nodig hebt
  1. Sony WH-1000XM5 Battery Replacement, Earpads: stap 1, afbeelding 1 van 3 Sony WH-1000XM5 Battery Replacement, Earpads: stap 1, afbeelding 2 van 3 Sony WH-1000XM5 Battery Replacement, Earpads: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    iFixit Opening Tool
    $1.99
    • Place the edge of an iFixit opening tool under the earpad cushion.
    • Slide it alongside the edge of the cushion until it detaches from the rest of the headphones.
    Vraag FixBot
    Voeg opmerking toe
  2. Sony WH-1000XM5 Battery Replacement, Battery: stap 2, afbeelding 1 van 2 Sony WH-1000XM5 Battery Replacement, Battery: stap 2, afbeelding 2 van 2
    Phillips #000 Screwdriver
    $5.49
    • Use a Phillips #000 screwdriver to remove the eight screws along the outer inside edge.
    • There is a piece of grey foam you can simply remove to uncover the centre 4 screws.
    • Flip the headphones to the other side and slowly lift up the back plastic cover piece.
    • Gently disconnect the touch sensor ribbon cable by pulling it out evenly from the main board.
    Vraag FixBot
    Voeg opmerking toe
  3. Sony WH-1000XM5 Battery Replacement: stap 3, afbeelding 1 van 3 Sony WH-1000XM5 Battery Replacement: stap 3, afbeelding 2 van 3 Sony WH-1000XM5 Battery Replacement: stap 3, afbeelding 3 van 3
    • Peel off the tape covering the battery connector.
    • Pull out the battery and disconnect the battery cable from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
4 andere personen hebben deze handleiding voltooid.
Miranda
243 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-4, Santin Spring 2024 Lid van UMass Dartmouth, Team 1-4, Santin Spring 2024
UMASSD-SANTIN-S24S1G4
3 Leden
8 handleidingen geschreven
1Gids Commentaar
Hey folks, thanks for taking the time to layout this procedure. These headphones are amazing, and this really helps me get my friends onboard.
placebomessiah - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 23
Afgelopen 7 dagen: 186
Afgelopen 30 dagen: 796
Altijd: 19,201
