Sony TCM-450 Battery Cover Replacement
Inleiding
Ga naar stap 1Is your Sony TCM-450 or TCM-450DV battery cover broken and/or won't close? Then this guide will direct you through the process of replacing the battery cover on the device. The Sony TCM-450 battery cover does more than simply cover the batteries in the device. It also prevents the Sony TCM-450 back cabinet from being removed.
Wat je nodig hebt
Remove the two 3.5 mm Phillips #00 screws from the bottom of the device.
Carefully remove the three inner screws as shown from the circuit board to loosen it.
Remove the following screws in this order:
A 3.4 mm Phillips #00
A 4.6 mm Phillips #00
A 9.7 mm Phillips #0
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
