Ga door naar hoofdinhoud
Sonos Playbase Ethernet Port Replacement
James Andrews
James Andrews en 3 andere bijdragers
Voor het laatst geüpdatet op December 5, 2018
5 minuten
Gemiddeld
This guide shows how to replace the Ethernet Port from the Sonos Playbase, which connects the Playbase to the internet.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Sonos Playbase Ethernet Port Replacement, Bottom Panel: stap 1, afbeelding 1 van 3 Sonos Playbase Ethernet Port Replacement, Bottom Panel: stap 1, afbeelding 2 van 3 Sonos Playbase Ethernet Port Replacement, Bottom Panel: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Pro Tech Toolkit
    $74.95
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase Ethernet Port Replacement: stap 2, afbeelding 1 van 2 Sonos Playbase Ethernet Port Replacement: stap 2, afbeelding 2 van 2
    Pro Tech Toolkit
    $74.95
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase Ethernet Port Replacement: stap 3, afbeelding 1 van 2 Sonos Playbase Ethernet Port Replacement: stap 3, afbeelding 2 van 2
    Pro Tech Toolkit
    $74.95
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase Ethernet Port Replacement, Ethernet Port: stap 4, afbeelding 1 van 2 Sonos Playbase Ethernet Port Replacement, Ethernet Port: stap 4, afbeelding 2 van 2
    • Unplug the Ethernet Port from the main circuit board by pinching the white clip and pulling upward.
  5. Sonos Playbase Ethernet Port Replacement: stap 5, afbeelding 1 van 2 Sonos Playbase Ethernet Port Replacement: stap 5, afbeelding 2 van 2
    Pro Tech Toolkit
    $74.95
    • Remove the two 18 mm T-10 screws holding the Ethernet Port in place by turning them counterclockwise.
  6. Sonos Playbase Ethernet Port Replacement: stap 6, afbeelding 1 van 2 Sonos Playbase Ethernet Port Replacement: stap 6, afbeelding 2 van 2
    • Remove the Ethernet Port from the housing by pinching from both sides and pulling it out.
Conclusie
James Andrews
421 Reputatie
4 handleidingen geschreven
Cal Poly, Team S17-G2, White Fall 2018 Lid van Cal Poly, Team S17-G2, White Fall 2018
CPSU-WHITE-F18S17G2
4 Leden
8 handleidingen geschreven
Één opmerking
I actually have a broken ethernet port on a playbase. Do you have any idea where I can buy a replacement port?
Thanks,
D
david paler - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 22
Altijd: 1,621
