Ga door naar hoofdinhoud
Sol Republic Deck Battery Replacement
Ross Bolton
Ross Bolton en 5 andere bijdragers
Voor het laatst geüpdatet op May 7, 2024
20 minuten - 1 uur
Gemiddeld
Onjuiste gereedschappen
Betere introductie
This guide will walk you through the process of replacing your broken, dead, or dying battery in your Motorola X Sol Republic Deck.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Sol Republic Deck Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Battery Replacement: stap 2, afbeelding 1 van 1
    • Use the screwdriver to unscrew 2 3.63mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove ribbon cable from the circuit board.
  4. Sol Republic Deck Battery Replacement: stap 4, afbeelding 1 van 2 Sol Republic Deck Battery Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
    • The ribbon cables are adhesive attached to the case, use tweezers to VERY carefully pick them up. They will then lift up with the circuit board. Or desolder them at the bottom to separate from the circuit board.
    • Melt the solder with an iron and used the tweezers to pull the wire upright.
    • You can pull the circuit board up and away from the wires once the wires are pointed up.
  5. Sol Republic Deck Battery Replacement: stap 5, afbeelding 1 van 1
    • Unscrew eighteen 6.2 mm Phillips #0 screws and lift the black plastic plate from the case.
  6. Sol Republic Deck Battery Replacement: stap 6, afbeelding 1 van 3 Sol Republic Deck Battery Replacement: stap 6, afbeelding 2 van 3 Sol Republic Deck Battery Replacement: stap 6, afbeelding 3 van 3
    • Unscrew both 3.6 mm Phillips #0 screws holding the battery case to the back of the plastic plate.
    • Remove the battery from the battery case.
    • Original battery is ICR18650-30A. Its rated for 3000mAh, 6A continuous (2 C-rate).
Conclusie
4 andere personen hebben deze handleiding voltooid.
Ross Bolton
133 Reputatie
1 Handleiding geschreven
IUPUI, Team S3-G1, Baechle Spring 2017 Lid van IUPUI, Team S3-G1, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G1
3 Leden
3 handleidingen geschreven
10 opmerkingen
I appreciate the battery replacement for the deck,but what about battery replacement
For the deck ultra
chai4i - Antwoord
What type of battery is it?
Peter Perez - Antwoord
It's just a regular lithium ion 18650 battery 3.7v 3200-3500 mah. The deck ultra uses 2 of these
Aaron Linn - Antwoord
The wires which are blue and purple are connected to battery body if im not wrong
vineeth m -
After changing the battery my device is not switching on. Please help. I connected the charger the battery is charging... showing red.
vineeth m - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 70
Altijd: 8,549
