Ga door naar hoofdinhoud
Sharp Aquos Crystal Screen Replacement
Felicia Imbriano
Felicia Imbriano en 2 andere bijdragers
Voor het laatst geüpdatet op January 27, 2022
Geen schatting
Gemiddeld
Ontbrekende stappen
If you cracked your screen or you are having issues with the touch screen, you may need to replace the screen.
Wat je nodig hebt
Gereedschap
  1. Sharp Aquos Crystal Screen Replacement, Back Panel: stap 1, afbeelding 1 van 3 Sharp Aquos Crystal Screen Replacement, Back Panel: stap 1, afbeelding 2 van 3 Sharp Aquos Crystal Screen Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Peel back the back cover of the phone from the access point to remove it. It should come off easily using your hands.
    Sense4liteなんですけど全く取れないです
    kpt - Antwoord
    Helo my back camera problem please Oder my camera
    Umar Umar - Antwoord
  2. Sharp Aquos Crystal Screen Replacement, USB Port: stap 2, afbeelding 1 van 2 Sharp Aquos Crystal Screen Replacement, USB Port: stap 2, afbeelding 2 van 2
    • Remove seven 3mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 3.5mm Star #5 screws shown in the picture with a screwdriver.
    • Remove two 5mm Star #5 screws shown in the picture with a screwdriver.
  3. Sharp Aquos Crystal Screen Replacement: stap 3, afbeelding 1 van 2 Sharp Aquos Crystal Screen Replacement: stap 3, afbeelding 2 van 2
    • Pry open the back panel using a plastic opening tool. Do this around the edges until you are able to lift it off.
  4. Sharp Aquos Crystal Screen Replacement: stap 4, afbeelding 1 van 2 Sharp Aquos Crystal Screen Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the wire by lifting it up with a plastic opening tool.
    what does the wire go to
    Aven Myers - Antwoord
  5. Sharp Aquos Crystal Screen Replacement: stap 5, afbeelding 1 van 3 Sharp Aquos Crystal Screen Replacement: stap 5, afbeelding 2 van 3 Sharp Aquos Crystal Screen Replacement: stap 5, afbeelding 3 van 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  6. Sharp Aquos Crystal Screen Replacement: stap 6, afbeelding 1 van 1
    • After removing the wires, carefully snap out the usb port with your hands. It is held down by some plastic clips, so some force may be needed.
    Hello
    I would like to buy a Sharp c10 Aquos Crystal USB Port
    Can you help me with that ???
    ابو مصطفى - Antwoord
    I need this part (aquos r2) I'm from Pakistan
    Faisal Abbas - Antwoord
  7. Sharp Aquos Crystal Screen Replacement, Motherboard: stap 7, afbeelding 1 van 1
    • Peel off the black pieces of tape.
  8. Sharp Aquos Crystal Screen Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the cable out using tweezers.
  9. Sharp Aquos Crystal Screen Replacement: stap 9, afbeelding 1 van 2 Sharp Aquos Crystal Screen Replacement: stap 9, afbeelding 2 van 2
    • Remove the wire from the two marked connections using tweezers to pull the wire apart from the device.
  10. Sharp Aquos Crystal Screen Replacement: stap 10, afbeelding 1 van 1
    • Peel the tape off with your hands.
  11. Sharp Aquos Crystal Screen Replacement: stap 11, afbeelding 1 van 1
    • Lift the motherboard out with your hands.
  12. Sharp Aquos Crystal Screen Replacement, Battery: stap 12, afbeelding 1 van 1
    • Peel off the tape holding the battery down.
  13. Sharp Aquos Crystal Screen Replacement: stap 13, afbeelding 1 van 2 Sharp Aquos Crystal Screen Replacement: stap 13, afbeelding 2 van 2
    • Lift the battery out with your hands.
  14. Sharp Aquos Crystal Screen Replacement, Screen: stap 14, afbeelding 1 van 1
    • Replace this component with the new one.
    Aqous r3 screen replacement hai
    Abid Zaman - Antwoord
    I need it's parts
    Umer Rajpoot - Antwoord
Conclusie
Felicia Imbriano
1.230 Reputatie
8 handleidingen geschreven
UMass Dartmouth, Team 7-4, Catania Spring 2016 Lid van UMass Dartmouth, Team 7-4, Catania Spring 2016
UMASSD-CATANIA-S16S7G4
3 Leden
24 handleidingen geschreven
Één opmerking
Thanks! I did it!
Matteo Favero - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 130
Altijd: 10,017
