Ga door naar hoofdinhoud
Shark NV352 Roller Brush Motor Replacement
Wesley T Benica
Wesley T Benica en 3 andere bijdragers
Voor het laatst geüpdatet op September 29, 2022
15 - 20 minuten
Gemiddeld
If your roller brush is clear of debris, but still won't rotate, the roller brush motor may need to be replaced. Follow these steps to remove the roller brush motor for replacement.
Wat je nodig hebt
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Shark NV352 Roller Brush Motor Replacement, Roller Brush: stap 1, afbeelding 1 van 2 Shark NV352 Roller Brush Motor Replacement, Roller Brush: stap 1, afbeelding 2 van 2
    • Lift the latches on both sides of the vacuum to release the dust canister.
    • Remove the dust canister from the vacuum by lifting it up.
  2. Shark NV352 Roller Brush Motor Replacement: stap 2, afbeelding 1 van 1
    • Lay down the vacuum to access the bottom panel of the roller brush compartment.
  3. Shark NV352 Roller Brush Motor Replacement: stap 3, afbeelding 1 van 2 Shark NV352 Roller Brush Motor Replacement: stap 3, afbeelding 2 van 2
    • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
  4. Shark NV352 Roller Brush Motor Replacement: stap 4, afbeelding 1 van 2 Shark NV352 Roller Brush Motor Replacement: stap 4, afbeelding 2 van 2
    • Remove the eight 19mm Phillips #2 screws from the plastic cover.
    • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
  5. Shark NV352 Roller Brush Motor Replacement: stap 5, afbeelding 1 van 2 Shark NV352 Roller Brush Motor Replacement: stap 5, afbeelding 2 van 2
    • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
    • Remove the wheels by pulling them out of their axles, away from the vacuum.
  6. Shark NV352 Roller Brush Motor Replacement: stap 6, afbeelding 1 van 2 Shark NV352 Roller Brush Motor Replacement: stap 6, afbeelding 2 van 2
    • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
    • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
  7. Shark NV352 Roller Brush Motor Replacement: stap 7, afbeelding 1 van 1
    • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
  8. Shark NV352 Roller Brush Motor Replacement: stap 8, afbeelding 1 van 1
    • Take out the roller brush by lifting it out of its tray.
  9. Shark NV352 Roller Brush Motor Replacement, Roller Brush Motor: stap 9, afbeelding 1 van 1
    • The wires are attached to the motor, so take out the motor slowly to ensure that they do not break.
    • Remove the roller brush motor by carefully lifting it out of the vacuum.
  10. Shark NV352 Roller Brush Motor Replacement: stap 10, afbeelding 1 van 1
    • Desolder the wires running to the motor from the motherboard. For details on how to desolder, visit this soldering guide.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Wesley T Benica
378 Reputatie
2 handleidingen geschreven
Cal Poly, Team S18-G5, Forte Fall 2017 Lid van Cal Poly, Team S18-G5, Forte Fall 2017
CPSU-FORTE-F17S18G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 38
Altijd: 3,426
