Inleiding
This guide will demonstrate the necessary procedure to replace the earpiece assembly, including the earpiece speaker, proximity and gesture sensors, in the Samsung Galaxy S6 Edge.
This guide involves removing the rear glass. Removing the rear glass destroys the adhesive holding it in place. Follow this guide to reinstall the rear glass.
Insert a paper clip or SIM eject tool into the hole in the SIM card slot on top of the phone.
Press to eject the SIM card tray.
Remove the SIM card tray from the phone.
Lay the heated iOpener over the rear panel for about two minutes to loosen the adhesive around the edge of the glass.
Shift the iOpener to heat the remaining section of the panel for another two minutes.
Use tweezers to peel away any remaining adhesive from the phone's chassis.
Clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
Remove the thirteen 3.3 mm Phillips #00 screws from the midframe.
Using the flat end of the spudger, disconnect the battery ribbon cable from the motherboard.
Lift the earpiece assembly board from its routing channel above the earpiece speaker.
To reassemble your device, follow these instructions in reverse order. Follow this guide to reinstall the rear glass.
4 andere personen hebben deze handleiding voltooid.
