Ga door naar hoofdinhoud
Samsung Galaxy S10+ Front-Facing Camera Module Replacement
Wat je nodig hebt
Video overzicht
  1. Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Heat the back cover: stap 1, afbeelding 1 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Heat the back cover: stap 1, afbeelding 2 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Heat the back cover: stap 1, afbeelding 3 van 3
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
    Vraag FixBot
    Voeg opmerking toe
  2. Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Create an opening gap: stap 2, afbeelding 1 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Create an opening gap: stap 2, afbeelding 2 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Create an opening gap: stap 2, afbeelding 3 van 3
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts.
    • If you are having trouble creating a gap, your best bet is to apply more heat to the edge and try the previous step again.
    • You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    • Do not apply excessive force with the pick, or you will risk cracking the back cover glass.
    Vraag FixBot
    Voeg opmerking toe
  3. Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 3, afbeelding 1 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 3, afbeelding 2 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 3, afbeelding 3 van 3
    • Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
    • Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
    • Press the edge of an opening tool into the seam between the back cover and the frame.
    • Slide the opening tool back and forth along the seam a few times.
    Vraag FixBot
    Voeg opmerking toe
  4. Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Slice through the adhesive: stap 4, afbeelding 1 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Slice through the adhesive: stap 4, afbeelding 2 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Slice through the adhesive: stap 4, afbeelding 3 van 3
    • Slide the opening pick along the edge of the phone, slicing through the adhesive.
    • Do not attempt to slice the adhesive holding the corners down before applying heat. If you do, you may crack the back cover.
    • Leave a pick in the seam to prevent the adhesive from re-sealing.
    Vraag FixBot
    Voeg opmerking toe
  5. Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 5, afbeelding 1 van 1
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
    Vraag FixBot
    Voeg opmerking toe
  6. Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 6, afbeelding 1 van 2 Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 6, afbeelding 2 van 2
    • Insert an opening pick into the right edge near the bottom right corner.
    • Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
    • If the cutting feels difficult, re-apply heat to the edge before continuing.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
    Vraag FixBot
    Voeg opmerking toe
  7. Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 7, afbeelding 1 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 7, afbeelding 2 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 7, afbeelding 3 van 3
    • Continue heating and slicing around the remaining edges of the phone.
    • When cutting around corners, be sure that the corner is thoroughly heated.
    Vraag FixBot
    Voeg opmerking toe
  8. Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 8, afbeelding 1 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 8, afbeelding 2 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 8, afbeelding 3 van 3
    • Once you have sliced around the phone, twist an opening pick in one of the edges to help separate the back cover from the frame.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to reinstall the back cover, transfer and install the camera bezel, and replace the adhesive.
    Vraag FixBot
    Voeg opmerking toe
  9. Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Remove the midframe: stap 9, afbeelding 1 van 1
    • Remove the nine 4 mm Phillips screws securing the top midframe to the phone.
    Vraag FixBot
    Voeg opmerking toe
  10. Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 10, afbeelding 1 van 2 Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 10, afbeelding 2 van 2
    • The midframe is still held in place by a few plastic clips around the edge.
    • Insert the point of a spudger into the notch on the right edge of the midframe, near the Bixby button.
    • Pry up to loosen the midframe from the phone.
    Vraag FixBot
    Voeg opmerking toe
  11. Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 11, afbeelding 1 van 2 Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 11, afbeelding 2 van 2
    • Insert the point of a spudger into the notch on the left edge of the phone, located near the power button.
    Vraag FixBot
    Voeg opmerking toe
  12. Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 12, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  13. Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Disconnect the battery: stap 13, afbeelding 1 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Disconnect the battery: stap 13, afbeelding 2 van 3 Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Disconnect the battery: stap 13, afbeelding 3 van 3
    • Insert the flat end of a spudger underneath the battery connector, which is attached to the motherboard below the rear-facing camera.
    • Pry upwards to disconnect the connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently push the battery's flex cable away from the motherboard socket to prevent accidental contact.
    Vraag FixBot
    Voeg opmerking toe
  14. Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Front-Facing Camera Module: stap 14, afbeelding 1 van 2 Samsung Galaxy S10+ Front-Facing Camera Module Replacement, Front-Facing Camera Module: stap 14, afbeelding 2 van 2
    • Use the point of a spudger to pry up and disconnect the front-facing camera connector from its motherboard socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Vraag FixBot
    Voeg opmerking toe
  15. Samsung Galaxy S10+ Front-Facing Camera Module Replacement: stap 15, afbeelding 1 van 1
    • Remove the front-facing camera module.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
After you've completed the repair, follow this guide to test your repair.
7 andere personen hebben deze handleiding voltooid.
Arthur Shi
343.753 Reputatie
915 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
28.477 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 68
Altijd: 4,234
