Repairing Cup Holder for 2008 328i BMW
Inleiding
Ga naar stap 1If you have a cup holder but it wont open then this guide will take you through the steps you need to do to fix this problem.
Wat je nodig hebt
Gereedschap
Toon meer…
Apply putty knife to edge of cover until it pops open
Remove screws off of broken cup holder
Take cup holder out
Follow these steps step by step to get your broken cup holder fixed.
19 andere personen hebben deze handleiding voltooid.
6 opmerkingen
Easy fix that saved over $60 if I had to purchase a new part and much much more if the the dealer were to have fixed this. Thank you
clever idea when plastic holding the spring hook is broken. nice hack of a fix.
Is there any way to purchase just the spring? In my case the plastic is fine, it’s the shaped metal tip of the spring that sheared off somehow!? I also need the tentioner.
This happened to me as well. I broke off the end of the coil/spring while bending to make a “hook” shape.
I looked for purchasing just the spring, but could not find it. Next up was the entire cupholder apparatus, either used ($~26), URO ($~39), or OEM/genuine BMW ($60-75+). This isn’t cheap and is not actually necessary to buy anything ,though.
Much easier is what I did instead, which was taking advantage of the coil material’s rigid/”easily-snap-off-able” property to make a new (wider) hook. I pulled the snapped end of the coil out a little, then put in a thin screwdriver to kind of hold the coil out extended. Next I used flat nose pliers to hold the end flat, while using long nose pliers to break off a new gap on both sides, effectively making a new “t” end. Then of course I VERY GENTLY bent it around to make a “hook”. I gently clipped the new spring hook into the preexisting plastic hole. It works for new after reinstalling. We’ll see how it holds up!
Dealer wanted $180. Flat spring has T on end and locks into corresponding T in plastic. My plastic was broken out on one side. I merely took a bit in my dremel, and made the old T deeper in order to catch the metal end.
