Ga door naar hoofdinhoud
Razer Blade 15" (2018) RAM Replacement
Wat je nodig hebt
    1. Razer Blade 15" (2018) RAM Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 1 van 2 Razer Blade 15" (2018) RAM Replacement, Prepare your laptop for disassembly: stap 1, afbeelding 2 van 2
      • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
      • Unplug all cables, fully shut down your laptop, and close the lid.
      Vraag FixBot
      Voeg opmerking toe
    1. Razer Blade 15" (2018) RAM Replacement, Unfasten the back cover: stap 2, afbeelding 1 van 1
      • Rotate your laptop so the screen hinge is farthest from you.
      • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: stap 3, afbeelding 1 van 3 Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: stap 3, afbeelding 2 van 3 Razer Blade 15" (2018) RAM Replacement, Insert an opening pick: stap 3, afbeelding 3 van 3
      • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
      • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
      • Pull up on the suction handle to create a small gap between the back cover and the frame.
      • Insert an opening pick into the gap.
      Vraag FixBot
      Voeg opmerking toe
    3. Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: stap 4, afbeelding 1 van 3 Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: stap 4, afbeelding 2 van 3 Razer Blade 15" (2018) RAM Replacement, Angle the opening pick: stap 4, afbeelding 3 van 3
      • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
      • Insert your pick up to 10 mm (0.4 in) deep.
      Vraag FixBot
      Voeg opmerking toe
    4. Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: stap 5, afbeelding 1 van 3 Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: stap 5, afbeelding 2 van 3 Razer Blade 15" (2018) RAM Replacement, Free the bottom right corner: stap 5, afbeelding 3 van 3
      • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
      Vraag FixBot
      Voeg opmerking toe
    5. Razer Blade 15" (2018) RAM Replacement, Free the front edge: stap 6, afbeelding 1 van 3 Razer Blade 15" (2018) RAM Replacement, Free the front edge: stap 6, afbeelding 2 van 3 Razer Blade 15" (2018) RAM Replacement, Free the front edge: stap 6, afbeelding 3 van 3
      • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
      Vraag FixBot
      Voeg opmerking toe
    6. Razer Blade 15" (2018) RAM Replacement, Remove the back cover: stap 7, afbeelding 1 van 3 Razer Blade 15" (2018) RAM Replacement, Remove the back cover: stap 7, afbeelding 2 van 3 Razer Blade 15" (2018) RAM Replacement, Remove the back cover: stap 7, afbeelding 3 van 3
      • Remove the back cover.
      • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
      Vraag FixBot
      Voeg opmerking toe
    1. Razer Blade 15" (2018) RAM Replacement, Soften the battery cable tape adhesive: stap 8, afbeelding 1 van 2 Razer Blade 15" (2018) RAM Replacement, Soften the battery cable tape adhesive: stap 8, afbeelding 2 van 2
      • Apply a heated iOpener to the battery cable tape for one minute.
      • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
      Vraag FixBot
      Voeg opmerking toe
    2. Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: stap 9, afbeelding 1 van 3 Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: stap 9, afbeelding 2 van 3 Razer Blade 15" (2018) RAM Replacement, Peel up the battery cable tape: stap 9, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Be careful not to damage the battery with your tool.
      • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
      Vraag FixBot
      Voeg opmerking toe
    3. Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: stap 10, afbeelding 1 van 3 Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: stap 10, afbeelding 2 van 3 Razer Blade 15" (2018) RAM Replacement, Disconnect the battery: stap 10, afbeelding 3 van 3
      • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
      Vraag FixBot
      Voeg opmerking toe
    1. Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: stap 11, afbeelding 1 van 3 Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: stap 11, afbeelding 2 van 3 Razer Blade 15" (2018) RAM Replacement, Remove the lower RAM stick: stap 11, afbeelding 3 van 3
      • Two metal arms secure the left and right edges of each RAM stick.
      • Push the lower RAM stick's metal arms outward to disengage them.
      • Remove the RAM stick.
      • During reassembly, insert the RAM stick at a 30-degree angle, then push straight down to engage the metal arms.
      Vraag FixBot
      Voeg opmerking toe
    2. Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: stap 12, afbeelding 1 van 3 Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: stap 12, afbeelding 2 van 3 Razer Blade 15" (2018) RAM Replacement, Remove the upper RAM stick: stap 12, afbeelding 3 van 3
      • Disengage the upper RAM stick's arms and remove the RAM.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Clay Eickemeyer
105.984 Reputatie
472 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
10 Leden
36.498 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 696
