Philips Norelco MultiGroom 3100 Motor Replacement
Inleiding
Ga naar stap 1This guide will teach you how to replace the motor and will require some soldering.
Wat je nodig hebt
Gereedschap
Toon meer…
Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use the tweezers to pull out the inner power button.
4 andere personen hebben deze handleiding voltooid.
4 opmerkingen
¿Me puedes ayudar con algo?
Can you help me with something?
this guide was created also by nina lovekrist in 2015
Where can I get the motor with copper shaft?
