Philips HD9252 Transformer Replacement
Inleiding
Ga naar stap 1Follow this guide for instructions on how to remove and replace the air fryer's transformer. Removal of the transformer may be required if the device is being taken to another country where power outlets are different from the United States.
Wat je nodig hebt
Gereedschap
Toon meer…
Insert a nylon spudger underneath the top of the device.
Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
Remove the two 39.5 mm screws attached to the black piece of the transformer using a JIS #1 screwdriver.
Één opmerking
This is not the transformer, it is the coil of the shaded-pole motor.
