Ga door naar hoofdinhoud
Philips HD9252 Transformer Replacement
Wat je nodig hebt
  1. Philips HD9252 Transformer Replacement, Top: stap 1, afbeelding 1 van 1
    • Insert a nylon spudger underneath the top of the device.
    • Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
  2. Philips HD9252 Transformer Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 12.4 mm screws in each of the corners using a JIS #1 screwdriver.
  3. Philips HD9252 Transformer Replacement: stap 3, afbeelding 1 van 1
    • Remove the top by lifting it upwards and setting it down.
    Hi, I cannot lift the top half because it's blocked by the exhaust vent. Any step that I am missing?
    Lorenzo Giraudi - Antwoord
  4. Philips HD9252 Transformer Replacement, Transformer: stap 4, afbeelding 1 van 1
    • Remove the two 39.5 mm screws attached to the black piece of the transformer using a JIS #1 screwdriver.
  5. Philips HD9252 Transformer Replacement: stap 5, afbeelding 1 van 1
    • Remove the top piece, using a Phillips #2 screwdriver, to get the whole transformer.
  6. Philips HD9252 Transformer Replacement: stap 6, afbeelding 1 van 2 Philips HD9252 Transformer Replacement: stap 6, afbeelding 2 van 2
    • Remove the brown and white wire attached to the transformer using a spudger.
    • Disconnect both the brown and white cables.
  7. Philips HD9252 Transformer Replacement: stap 7, afbeelding 1 van 1
    • Replace the transformer.
Conclusie
Zach Person
442 Reputatie
4 handleidingen geschreven
Één opmerking
This is not the transformer, it is the coil of the shaded-pole motor.
Werner Hinzmann - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 55
Altijd: 441
