Pentax Optio WG-2 LCD Screen Replacement
Inleiding
Ga naar stap 1Use this guide to replace the LCD viewing screen on the back of the Pentax Optio WG-2.
Wat je nodig hebt
Stap 1 Back Case
Voorzichtig: stappen 1-6 komen van een handleiding die in bewerking is.
Remove all four 1 mm JIS #00 screws from the back of the camera.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Carefully remove the clear tape covering the screws and the ribbon cable.
We want to remove the larger silver panel (right). The best way to do this is to slightly bend the cover backwards and use the tweezers to grab a corner and slowly lift the screen up and out.
2 opmerkingen
Dónde puedo comprar el Display?
Where I can buy the dispaly?
