Ga door naar hoofdinhoud
Opening Procedure
Wat je nodig hebt
  1. Opening Procedure, Power down your watch: stap 1, afbeelding 1 van 2 Opening Procedure, Power down your watch: stap 1, afbeelding 2 van 2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    Vraag FixBot
    Voeg opmerking toe
  2. Opening Procedure, Unfasten the back cover: stap 2, afbeelding 1 van 1
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
    Vraag FixBot
    Voeg opmerking toe
  3. Opening Procedure, Loosen the back cover adhesive: stap 3, afbeelding 1 van 1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    Vraag FixBot
    Voeg opmerking toe
  4. Opening Procedure, Pry up the back cover assembly: stap 4, afbeelding 1 van 3 Opening Procedure, Pry up the back cover assembly: stap 4, afbeelding 2 van 3 Opening Procedure, Pry up the back cover assembly: stap 4, afbeelding 3 van 3
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
    Vraag FixBot
    Voeg opmerking toe
  5. Opening Procedure, Disconnect the sensor assembly cable: stap 5, afbeelding 1 van 2 Opening Procedure, Disconnect the sensor assembly cable: stap 5, afbeelding 2 van 2
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Vraag FixBot
    Voeg opmerking toe
  6. Opening Procedure, Remove the back cover assembly: stap 6, afbeelding 1 van 3 Opening Procedure, Remove the back cover assembly: stap 6, afbeelding 2 van 3 Opening Procedure, Remove the back cover assembly: stap 6, afbeelding 3 van 3
    • Remove the back cover assembly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
3 andere personen hebben deze handleiding voltooid.
Dominik Schnabelrauch
260.495 Reputatie
682 handleidingen geschreven
iFixit Lid van iFixit
Staff
122 Leden
27.491 handleidingen geschreven
2Gids Commentaar
Whelp. I got it open thanks to this guide, but there's nothing I can see that would fix my main/power button not being responsive (thus the watch won't turn on anymore). Thanks anyway!
Hailey R - Antwoord Deel
Heb de batterij van mijn Ticwatch Pro 3 ultra succesvol kunnen vervangen. Ik zou enkel de specialized watch adhesive tape nog moeten hebben voor deze horloge om hem terug waterproof te hebben?
Patrick Vercammen - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 67
Altijd: 2,379
