Inleiding
The lens may be cracked, dirty, or just need to be replaced. This guide is a difficult guide which involves removing many elements of the camera and soldering to reach the lens.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Remove all of the screws that hold the back plate in place.
Unscrew the 4mm screw that is directly to the right of the viewfinder.
On the base,
Unscrew the 3mm screw in the top left corner.
Unscrew all four 3mm screws under the battery cover.
Unscrew the 3mm screw on the right side panel.
Unscrew the two 2mm screws on the left side panel.
Loosen the ribbon cables from the board.
1-Directly below the viewfinder.
2-At the Base of the board.
3-At the top right near the selector wheel. 1 on top of the board 2 on the underside.
1-The center of the board, above the central hole.
With metal tweezers, remove the two white plastic clips from their sockets one on the base of the board and the other on the surface.
Now we remove the bulk of the cameras components from the front of the case.
Unscrew the 2-3mm Screws from the right side of the casing
Pop the flash up, to get access to the two body screws underneath
Undo the 2-3mm screws
Één andere persoon heeft deze handleiding voltooid.
