Ga door naar hoofdinhoud
Nintendo 2DS Volume Slider Replacement
S. Leng
S. Leng en 3 andere bijdragers
Voor het laatst geüpdatet op March 11, 2025
20 - 40 minuten
Gemiddeld
This guide will show you how to replace the volume slider of your Nintendo 2DS. The volume slider may not break often but if you find yourself with a slider that is stuck in place or you're unable to control the level of volume, this guide may help.
Before beginning this repair, turn off the device.
Wat je nodig hebt
Gereedschap
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Nintendo 2DS Volume Slider Replacement, Volume Slider: stap 1, afbeelding 1 van 3 Nintendo 2DS Volume Slider Replacement, Volume Slider: stap 1, afbeelding 2 van 3 Nintendo 2DS Volume Slider Replacement, Volume Slider: stap 1, afbeelding 3 van 3
    • Turn the 2DS over so that the backside is facing upwards.
    • Identify the two Phillips #00 screws on the upper rear panel.
  2. Nintendo 2DS Volume Slider Replacement: stap 2, afbeelding 1 van 3 Nintendo 2DS Volume Slider Replacement: stap 2, afbeelding 2 van 3 Nintendo 2DS Volume Slider Replacement: stap 2, afbeelding 3 van 3
    • Loosen the two screws on the upper back panel using a Phillips #00 screwdriver.
    • The screws are captive and will not detach from the back panel or separate from the panel upon removal.
    • Use a spudger to pry the upper back panel off, starting at the indent at the center top of the panel.
    • Use a spudger and work your way around the perimeter to release the clips and then lift the panel off.
  3. Nintendo 2DS Volume Slider Replacement: stap 3, afbeelding 1 van 3 Nintendo 2DS Volume Slider Replacement: stap 3, afbeelding 2 van 3 Nintendo 2DS Volume Slider Replacement: stap 3, afbeelding 3 van 3
    • Use your finger or a spudger to lift and pull the battery outwards from the side closest to the outer edge.
  4. Nintendo 2DS Volume Slider Replacement: stap 4, afbeelding 1 van 3 Nintendo 2DS Volume Slider Replacement: stap 4, afbeelding 2 van 3 Nintendo 2DS Volume Slider Replacement: stap 4, afbeelding 3 van 3
    • Pull the stylus out from the middle of the left edge of the device.
    • Use a Phillips #00 screwdriver to remove ten 2.0 mm screws from the back panel.
    • Unlike the top rear panel, these screws come out, so be sure to keep them in a safe place.
  5. Nintendo 2DS Volume Slider Replacement: stap 5, afbeelding 1 van 3 Nintendo 2DS Volume Slider Replacement: stap 5, afbeelding 2 van 3 Nintendo 2DS Volume Slider Replacement: stap 5, afbeelding 3 van 3
    • Use a spudger to pry the back case off by working around the perimeter of the device, starting from the bottom of the 2DS.
    • Don't yank or pull the back case off because the camera ribbon is attached to the motherboard and back case and may rip or damage the cable or camera itself.
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the camera cable.
    • Use your spudger to gently slide the cable out of the connector.
    • Remove the back case.
  6. Nintendo 2DS Volume Slider Replacement: stap 6, afbeelding 1 van 3 Nintendo 2DS Volume Slider Replacement: stap 6, afbeelding 2 van 3 Nintendo 2DS Volume Slider Replacement: stap 6, afbeelding 3 van 3
    • Gently pry the side that holds the volume slider off of the 2DS.
  7. Nintendo 2DS Volume Slider Replacement: stap 7, afbeelding 1 van 3 Nintendo 2DS Volume Slider Replacement: stap 7, afbeelding 2 van 3 Nintendo 2DS Volume Slider Replacement: stap 7, afbeelding 3 van 3
    • Remove the volume slider from the sidebar housing.
Conclusie
S. Leng
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 56
Afgelopen 30 dagen: 231
Altijd: 2,950
