Ga door naar hoofdinhoud
Nikon Coolpix AW130 Motherboard Replacement
Lauren Stepp
Lauren Stepp en een andere bijdrager
Voor het laatst geüpdatet op June 18, 2020
55 minuten
Moeilijk
The motherboard is the key component to making the camera run. If there is a faulty connection, the camera will not turn on at all. This repair should be completed with care, as to not interrupt the flow of power.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. Nikon Coolpix AW130 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Nikon Coolpix AW130 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Motherboard Replacement: stap 2, afbeelding 1 van 2 Nikon Coolpix AW130 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Motherboard Replacement: stap 4, afbeelding 1 van 2 Nikon Coolpix AW130 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Motherboard Replacement, Front Panel: stap 5, afbeelding 1 van 2 Nikon Coolpix AW130 Motherboard Replacement, Front Panel: stap 5, afbeelding 2 van 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Motherboard Replacement: stap 6, afbeelding 1 van 2 Nikon Coolpix AW130 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
  7. Nikon Coolpix AW130 Motherboard Replacement, Back Panel: stap 7, afbeelding 1 van 2 Nikon Coolpix AW130 Motherboard Replacement, Back Panel: stap 7, afbeelding 2 van 2
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
  8. Nikon Coolpix AW130 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  9. Nikon Coolpix AW130 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
  10. Nikon Coolpix AW130 Motherboard Replacement: stap 10, afbeelding 1 van 2 Nikon Coolpix AW130 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
  11. Nikon Coolpix AW130 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Carefully remove the back cover from the camera body.
  12. Nikon Coolpix AW130 Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 2 Nikon Coolpix AW130 Motherboard Replacement, Motherboard: stap 12, afbeelding 2 van 2
    • Using a Phillips #000 screwdriver, remove all 8, 4mm screws on the motherboard.
  13. Nikon Coolpix AW130 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Using the nylon spudger tool, peel back the metallic plate.
    • A metal spudger is shown in the photo, but a nylon spudger should be used.
    • Do not rip the gold-colored ribbons.
  14. Nikon Coolpix AW130 Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Using your fingers, carefully disconnect the connector ribbons.
    • Though various guides suggest using a plastic or metal spudger tool to disconnect the ribbons, this tool is liable to damage the connectors.
  15. Nikon Coolpix AW130 Motherboard Replacement: stap 15, afbeelding 1 van 1
    • Carefully remove the black piece on the lefthand side.
  16. Nikon Coolpix AW130 Motherboard Replacement: stap 16, afbeelding 1 van 1
    • On the remaining piece, desolder the labeled soldering points.
    • The soldering tool can get extremely hot. For soldering help, check out iFixit's guide for How to Solder and Desolder Connections.
  17. Nikon Coolpix AW130 Motherboard Replacement: stap 17, afbeelding 1 van 1
    • Flip the remaining piece over, careful not to rip any of the connecting wires.
  18. Nikon Coolpix AW130 Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Desolder at the prescribed sites.
    • Remove the motherboard from the camera body.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Lauren Stepp
1.251 Reputatie
8 handleidingen geschreven
Één opmerking
Thanks for this guide.
I managed to open 2 of theses and swap the sensor-unit from one to another.
Unluckily the camera remains broken since one only shows a black picture - even though the sensor is alright an the other has a broken AF from a fall, I suppose...
I am certain with some silicone grease on the orange rubber the camera would still be waterproof.
Daniel Bardua - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 33
Altijd: 5,459
