Ga door naar hoofdinhoud
Motorola Edge (2022) Back Cover Replacement
Wat je nodig hebt
  1. Motorola Edge (2022) Back Cover Replacement, Heat the right edge: stap 1, afbeelding 1 van 1
    • Completely power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: stap 2, afbeelding 1 van 3 Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: stap 2, afbeelding 2 van 3 Motorola Edge (2022) Back Cover Replacement, Separate the right adhesive: stap 2, afbeelding 3 van 3
    • Apply a suction cup to the back of the phone, as close to the middle of the right edge as possible.
    • Pull up on the suction cup with a strong, steady force to create a gap between the back cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • Insert an opening pick into the gap.
  3. Motorola Edge (2022) Back Cover Replacement, Slice the right adhesive: stap 3, afbeelding 1 van 2 Motorola Edge (2022) Back Cover Replacement, Slice the right adhesive: stap 3, afbeelding 2 van 2
    • Slide the pick along the right edge to slice the adhesive.
    • Leave the pick in the bottom right edge to prevent the adhesive from resealing.
  4. Motorola Edge (2022) Back Cover Replacement, Heat the bottom edge: stap 4, afbeelding 1 van 1
    • Apply a heated iOpener to the back cover's bottom edge for two minutes.
  5. Motorola Edge (2022) Back Cover Replacement, Slice the bottom right corner adhesive: stap 5, afbeelding 1 van 2 Motorola Edge (2022) Back Cover Replacement, Slice the bottom right corner adhesive: stap 5, afbeelding 2 van 2
    • Rotate the pick around the bottom right corner to slice the adhesive.
  6. Motorola Edge (2022) Back Cover Replacement: stap 6, afbeelding 1 van 2 Motorola Edge (2022) Back Cover Replacement: stap 6, afbeelding 2 van 2
    • Slide the pick along the bottom edge to slice the adhesive.
    • Leave the pick in the bottom left edge to prevent the adhesive from resealing.
  7. Motorola Edge (2022) Back Cover Replacement: stap 7, afbeelding 1 van 1
    • Apply a heated iOpener to the back cover's left edge for two minutes.
  8. Motorola Edge (2022) Back Cover Replacement: stap 8, afbeelding 1 van 2 Motorola Edge (2022) Back Cover Replacement: stap 8, afbeelding 2 van 2
    • Rotate the pick around the bottom left corner to slice the adhesive.
  9. Motorola Edge (2022) Back Cover Replacement: stap 9, afbeelding 1 van 2 Motorola Edge (2022) Back Cover Replacement: stap 9, afbeelding 2 van 2
    • Slide the pick along the edge to slice the adhesive.
    • Leave the pick in the top left edge to prevent the adhesive from resealing.
  10. Motorola Edge (2022) Back Cover Replacement: stap 10, afbeelding 1 van 1
    • Apply a heated iOpener to the back cover's top edge for two minutes.
  11. Motorola Edge (2022) Back Cover Replacement: stap 11, afbeelding 1 van 2 Motorola Edge (2022) Back Cover Replacement: stap 11, afbeelding 2 van 2
    • Rotate the pick around the top left corner to slice the adhesive.
  12. Motorola Edge (2022) Back Cover Replacement: stap 12, afbeelding 1 van 2 Motorola Edge (2022) Back Cover Replacement: stap 12, afbeelding 2 van 2
    • Slide the pick along the top edge to slice the adhesive.
  13. Motorola Edge (2022) Back Cover Replacement, Remove the back cover: stap 13, afbeelding 1 van 2 Motorola Edge (2022) Back Cover Replacement, Remove the back cover: stap 13, afbeelding 2 van 2
    • Lift the back cover from the phone and remove it.
    • If the back cover is still stuck to the midframe, slide an opening pick around the edges of the phone until the cover separates completely.
Conclusie
To reassemble your device, follow the instructions in reverse order.
Spencer Day
59.654 Reputatie
430 handleidingen geschreven
iFixit Lid van iFixit
Staff
141 Leden
17.895 handleidingen geschreven
Één opmerking
Where can I find the rear cover to replace it with? Mine is spiderwebbed.
bigrebone - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 48
Altijd: 1,398
