Ga door naar hoofdinhoud
Motorola Droid Turbo 2 Rear Cover Adhesive Guide
Arthur Shi
Arthur Shi en 2 andere bijdragers
Voor het laatst geüpdatet op May 7, 2024
15 - 45 minuten
Eenvoudig
This guide will show you how to apply new adhesive to the rear cover of your Motorola Droid Turbo 2 to seal it up after a repair.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. Motorola Droid Turbo 2 Rear Cover Adhesive Guide, Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 1, afbeelding 1 van 3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide, Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 1, afbeelding 2 van 3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide, Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Prepare the phone frame surface by removing all traces of adhesive.
    • Use tweezers to pull adhesive chunks off. Use the opening tool to scrape residue off. You can use high concentration (over 90%) isopropyl alcohol to help dissolve residue.
    • Be careful not to damage the wireless charging coil when scraping around it.
    • If you are re-using the rear cover, prepare the inner surface by removing all traces of adhesive from it.
    • Do not attempt to remove the rectangular plastic liner near the bottom of the cover, but do scrape off all adhesive on it.
  2. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 2, afbeelding 1 van 1
    • Use your finger and firmly press the metal rear camera plate from the outer side of the rear cover until you dislodge it from its recess.
    • Remove the rear camera plate.
    • Clean the perimeter of the rear camera plate and remove any adhesive residue.
  3. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 3, afbeelding 1 van 2 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 3, afbeelding 2 van 2
    • Set the pre-cut adhesive strip next to the rear cover so that it is properly oriented—the pull tabs should point to the bottom left corner of the cover.
    • Optionally, you can tape the pre-cut adhesive strip into position for easier application.
    • Lay the pre-cut adhesive strip over the rear cover, aligning it to the long edges.
    • Tape one long edge of the pre-cut adhesive strip to the rear cover, locking the alignment in place while allowing the strip to still swing.
  4. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 4, afbeelding 1 van 2 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 4, afbeelding 2 van 2
    • Peel and remove the clear plastic liner from the pre-cut adhesive strip.
    • This will expose adhesive facing the rear cover, so don't remove the liner until you are ready to begin placement.
  5. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 5, afbeelding 1 van 3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 5, afbeelding 2 van 3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 5, afbeelding 3 van 3
    • The exposed adhesive is very sticky and prone to adhering to surfaces unintentionally. Be careful while handling and aligning the adhesive.
    • Align the adhesive strip to a long edge of the rear cover.
    • If you have previously taped the adhesive strip to the rear cover, the strip should already be aligned.
    • Beginning from the alignment edge, use your fingers to press the adhesive strip onto the rear cover.
  6. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 6, afbeelding 1 van 2 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 6, afbeelding 2 van 2
    • Pull and remove the blue liner tab located in the rear cover's rear camera hole.
    • This will expose a ring of adhesive around the hole, which will hold the rear camera plate in place.
  7. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 7, afbeelding 1 van 3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 7, afbeelding 2 van 3 Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 7, afbeelding 3 van 3
    • Align the rear camera plate with the rear cover's camera hole and drop it in place.
    • Press the rear camera plate in place. You may need to squeeze from both sides to ensure that the adhesive bonds properly.
  8. Motorola Droid Turbo 2 Rear Cover Adhesive Guide: stap 8, afbeelding 1 van 1
    • Continue with phone re-assembly until you are ready to seal up the phone.
    • Be sure to test your phone's functionality before sealing your phone.
    • Peel and remove the blue liner from the rear cover, exposing the adhesive to stick onto the phone frame.
    • Align and press the rear cover onto the phone frame.
Conclusie
Repair didn’t go as planned? Check out our Motorola Droid Turbo 2 Answers community for troubleshooting help.
8 andere personen hebben deze handleiding voltooid.
Arthur Shi
282.832 Reputatie
587 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.470 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 1,481
