Ga door naar hoofdinhoud
Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement
Wat je nodig hebt
  1. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement, Midframe: stap 1, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement, Midframe: stap 1, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement, Midframe: stap 1, afbeelding 3 van 3
    • Power off your phone before you begin working.
    • Insert a SIM eject tool, SIM eject bit, or a straightened paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • Remove the SIM card tray assembly from the phone.
  2. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 2, afbeelding 1 van 1
    • Heat an iOpener and apply it to the top edge of the phone for a minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 3, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 3, afbeelding 2 van 2
    • Angle an opening pick and firmly press so that it slips under the back cover.
    • Depending on the age of the phone, this can be difficult. Additional heating with the iOpener may help. You can pry carefully with a metal spudger to create a gap for the opening pick.
  4. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 4, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 4, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 4, afbeelding 3 van 3
    • Slide the opening pick along the top edge of the phone to break up the adhesive.
    • Use the pick to release the deeper areas but avoid slicing through the camera bezel area.
  5. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 5, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 5, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 5, afbeelding 3 van 3
    • Repeat the iOpener heating and slicing procedures for the remaining three sides.
    • Make sure to cut into the deeper areas as the back cover is held on by a large adhesive surface.
  6. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 6, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 6, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 6, afbeelding 3 van 3
    • Once you have cut through the adhesive, slowly peel the back cover away from the frame.
    • Remove the back cover.
    • During reassembly, follow this rear cover adhesive guide to properly apply the pre-cut adhesive strip.
  7. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 7, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 7, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 7, afbeelding 3 van 3
    • Insert an opening pick under the flash connector rubber cover and pry forward to remove it.
    • To reinstall the cover, align the cover and use your finger to push it forward into place.
  8. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 8, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 8, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 8, afbeelding 3 van 3
    • Use the point of a spudger to pry up and remove the coil connector rubber cover.
  9. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 9, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 9, afbeelding 2 van 2
    • Use the point of a spudger to pry up and disconnect the flash connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  10. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 10, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 10, afbeelding 2 van 2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil connector.
  11. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 11, afbeelding 1 van 1
    • Remove the following T3 screws securing the midframe:
    • Thirteen 3.1 mm black screws
    • Four 4.3 mm silver screws
    • Due to screw and bit variance, you may have better luck with a T4 driver. The proper bit should seat fully in the screwhead and feel slightly loose. The bit should not feel like it's stuck in the screwhead.
  12. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 12, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 12, afbeelding 2 van 2
    • Insert an opening pick along the frame seam and twist slightly to release the midframe from the phone.
  13. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 13, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 13, afbeelding 2 van 2
    • Remove the midframe from the phone.
    • You can tape over the side buttons to prevent them from falling out during your repair.
    • If the buttons fall out of the midframe, reinsert them in the orientation as shown before you reinstall the midframe.
  14. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement, Battery: stap 14, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement, Battery: stap 14, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement, Battery: stap 14, afbeelding 3 van 3
    • Carefully peel the black graphite layer from the phone.
    • While it is unnecessary for normal operation, the graphite layer can be reused during reinstallation if it is in good condition.
  15. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 15, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 15, afbeelding 2 van 2
    • Remove the two 4.2 mm T3 screws securing the metal bracket adjacent to the battery.
    • Remove the metal bracket.
  16. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 16, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 16, afbeelding 2 van 2
    • Use the point of a spudger to pry up and disconnect the battery pack connector.
  17. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 17, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 17, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 17, afbeelding 3 van 3
    • Angle and insert an opening pick under the long edge of the battery away from the motherboard side.
    • Insert a second opening pick along the same battery edge next to the first pick.
  18. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 18, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 18, afbeelding 2 van 2
    • Apply firm, constant prying pressure to the picks to release the battery from the frame.
    • As the battery loosens from the frame, move the picks inward and continue to pry upwards.
    • The battery is secured to the frame with strong double-sided tape. To help release the battery, apply some high concentration (90% or higher) isopropyl alcohol under the battery to help loosen the adhesive.
    • Don't deform or puncture the battery, or it may leak dangerous chemicals or catch fire.
  19. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 19, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Tesa 61395 Tape
    $5.99
    • Remove the battery.
    • Never reinstall a damaged or deformed battery. Replace the battery.
    • To reinstall the battery, orient it such that the wires exit near the bottom towards the motherboard side.
    • To help with alignment, connect the battery temporarily to the motherboard before adhering it in place. Disconnect the battery before you continue with re-assembly.
    • Clean off any adhesive residue which may prevent the battery from sitting flush against the frame. Use a few strips of adhesive included in the battery kit or some double-sided tape to secure the battery to the frame.
  20. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement, LCD Screen and Digitizer Assembly: stap 20, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement, LCD Screen and Digitizer Assembly: stap 20, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement, LCD Screen and Digitizer Assembly: stap 20, afbeelding 3 van 3
    • Insert an opening pick underneath the flat flex cable and slide it to free the cable from the frame.
  21. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 21, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 21, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 21, afbeelding 3 van 3
    • Use the point of a spudger to pry up and disconnect the antenna cable.
    • De-route the antenna cable from the phone.
  22. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 22, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 22, afbeelding 2 van 2
    • Use the flat end of a spudger to pry up and disconnect the accessory module connector.
  23. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 23, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 23, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 23, afbeelding 3 van 3
    • Peel away the yellow tape covering the display ZIF connector.
    • Use the flat end of a spudger to gently flip up the ZIF connector lock.
    • The ZIF lock is prone to breaking due to its width.
  24. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 24, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 24, afbeelding 2 van 2
    • Use a spudger or tweezers to walk the flat cable out of the ZIF connector.
  25. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 25, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 25, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 25, afbeelding 3 van 3
    • Peel away the yellow tape covering the digitizer ZIF connector.
    • Use the point of a spudger to flip up the ZIF connector lock.
  26. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 26, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 26, afbeelding 2 van 2
    • Use tweezers or a spudger to walk the ribbon cable out of the ZIF connector.
  27. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 27, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 27, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 27, afbeelding 3 van 3
    • Slide an opening pick underneath the motherboard below the copper shield.
    • Twist the pick slightly to release the adhesive tape securing the motherboard to the frame.
  28. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 28, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 28, afbeelding 2 van 2
    • Lift the motherboard out, making sure it does not catch on any cables.
    • Remove the motherboard.
  29. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 29, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 29, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 29, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up and disconnect the front facing camera connector.
    • Remove and transfer the front facing camera onto the new display frame.
  30. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 30, afbeelding 1 van 2 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 30, afbeelding 2 van 2
    • The earpiece speaker module is very delicate and prone to breaking. Be gentle when handling the module.
    • Insert a pointed end of a pair of tweezers into a corner as far down as possible.
    • Pry very slightly to help loosen the earpiece speaker module.
    • Repeat the process in the remaining corners.
  31. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 31, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 31, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 31, afbeelding 3 van 3
    • Continue to pry with the point of a pair of tweezers until the earpiece module feels loose.
    • Remove the earpiece module and transfer it to the new display frame.
  32. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 32, afbeelding 1 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 32, afbeelding 2 van 3 Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 32, afbeelding 3 van 3
    • Use the point of a spudger to pry up and remove the speaker grille cover.
    • Remove and transfer the speaker grille cover onto the new display frame.
  33. Motorola Droid Turbo 2 LCD Screen and Digitizer Assembly Replacement: stap 33, afbeelding 1 van 1
    Tesa 61395 Tape
    $5.99
    • Only the LCD screen and digitizer assembly (with frame) should remain.
    • Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
Conclusie
Repair didn’t go as planned? Check out our Motorola Moto Droid Turbo 2 Answers community for troubleshooting help.
6 andere personen hebben deze handleiding voltooid.
Arthur Shi
313.827 Reputatie
729 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.786 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 3,048
