Ga door naar hoofdinhoud
Meta Quest 2 Screen and Lens Assembly Replacement
Wat je nodig hebt
  1. Meta Quest 2 Screen and Lens Assembly Replacement, Power off your Meta Quest 2: stap 1, afbeelding 1 van 1
    • Hold the power button for three seconds to fully turn off your headset.
    • You'll hear a power down chime, and the LED next to the power button will turn off.
  2. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the facial interface: stap 2, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the facial interface: stap 2, afbeelding 2 van 2
    • Grasp and pull on the nose section of the facial interface to unclip it from the headset.
  3. Meta Quest 2 Screen and Lens Assembly Replacement: stap 3, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement: stap 3, afbeelding 2 van 2
    • Grasp and pull on the top section of the facial interface to unclip it from the headset.
  4. Meta Quest 2 Screen and Lens Assembly Replacement: stap 4, afbeelding 1 van 1
    • Remove the facial interface.
    • During reassembly, align the facial interface to the headset and use your fingers to press along the perimeter to clip it back in.
  5. Meta Quest 2 Screen and Lens Assembly Replacement, Unclip the side straps: stap 5, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Unclip the side straps: stap 5, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Unclip the side straps: stap 5, afbeelding 3 van 3
    • Use your fingers to grasp the right strap near the headset.
    • Peel the right strap away from the headset arm to unclip it.
  6. Meta Quest 2 Screen and Lens Assembly Replacement: stap 6, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement: stap 6, afbeelding 2 van 2
    • Repeat the procedure to peel the left strap away from the arm to unclip it.
  7. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the top strap: stap 7, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the top strap: stap 7, afbeelding 2 van 2
    • Separate the hook and loop strip on the top strap.
  8. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the head strap: stap 8, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the head strap: stap 8, afbeelding 2 van 2
    • Unthread the top strap from its bracket.
    • Remove the head strap.
  9. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the eyepiece trim screws: stap 9, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the eyepiece trim screws: stap 9, afbeelding 2 van 2
    • Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
  10. Meta Quest 2 Screen and Lens Assembly Replacement, Release the eyepiece trim clips: stap 10, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Release the eyepiece trim clips: stap 10, afbeelding 2 van 2
    • Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
  11. Meta Quest 2 Screen and Lens Assembly Replacement: stap 11, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 11, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 11, afbeelding 3 van 3
    • Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
    • Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
    • Leave the opening pick in the seam to prevent the clips from reengaging.
  12. Meta Quest 2 Screen and Lens Assembly Replacement: stap 12, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 12, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 12, afbeelding 3 van 3
    • Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
    • During reassembly, press your fingers along the perimeter of the eyepiece trim to clip it back in place.
  13. Meta Quest 2 Screen and Lens Assembly Replacement, Reposition the eyepiece trim: stap 13, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reposition the eyepiece trim: stap 13, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reposition the eyepiece trim: stap 13, afbeelding 3 van 3
    • Don’t try to fully remove the eyepiece trim in this step. It’s still connected to the headset by a short cable.
    • Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
    • Set the trim down on your work surface, making sure not to strain the cable.
  14. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the face sensor: stap 14, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the face sensor: stap 14, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the face sensor: stap 14, afbeelding 3 van 3
    • Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
  15. Meta Quest 2 Screen and Lens Assembly Replacement: stap 15, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement: stap 15, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to pull the face sensor cable out of the ZIF connector.
  16. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the eyepiece trim: stap 16, afbeelding 1 van 1
    • Remove the eyepiece trim.
  17. Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: stap 17, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: stap 17, afbeelding 2 van 2
    • During reassembly:
    • Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
    • If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
  18. Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: stap 18, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: stap 18, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: stap 18, afbeelding 3 van 3
    • During reassembly, the face sensor cable can be tricky to connect. Follow these tips to connect the cable:
    • Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
    • Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
    • Use a spudger to press the lock tab down towards the cable to lock it in place.
  19. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the front cover screws: stap 19, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the front cover screws: stap 19, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the front cover screws: stap 19, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
    • One recessed in the top-left corner
    • One recessed in the top-right corner
    • Three along the lower edge
  20. Meta Quest 2 Screen and Lens Assembly Replacement, Release the front cover clips: stap 20, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Release the front cover clips: stap 20, afbeelding 2 van 2
    • The front cover is still held in place by clips along the bottom and side edges.
    • Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
    • Pry with the opening pick to release the front cover clips.
  21. Meta Quest 2 Screen and Lens Assembly Replacement: stap 21, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 21, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 21, afbeelding 3 van 3
    • Slide the opening clip along the seam and pry to release all the clips securing the front cover.
  22. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the front cover: stap 22, afbeelding 1 van 1
    • Remove the front cover.
  23. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the top right antenna: stap 23, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the top right antenna: stap 23, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the top right antenna: stap 23, afbeelding 3 van 3
    • Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
    • Lift the antenna connector straight up to disconnect it.
    • Guide the antenna cable out of its metal clip holding it in place.
  24. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the battery cable bracket: stap 24, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
    • One 4.4 mm‑long screw
    • Two 2.3 mm‑long screws
  25. Meta Quest 2 Screen and Lens Assembly Replacement: stap 25, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 25, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 25, afbeelding 3 van 3
    • Use tweezers or your fingers to grasp the battery cable bracket.
    • Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
    • Remove the battery cable bracket.
  26. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the battery: stap 26, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the battery: stap 26, afbeelding 2 van 2
    • Use a spudger to pry up and disconnect the battery press connector from the motherboard.
    • The battery press connector can disconnect accidentally during reassembly. Check this connector before you attach the bracket.
  27. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the antenna: stap 27, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the antenna: stap 27, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the antenna: stap 27, afbeelding 3 van 3
    • Insert one arm of a pair of tweezers under the metal neck of the black antenna cable near the fan assembly.
  28. Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the front antenna assembly: stap 28, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the front antenna assembly: stap 28, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
    • Four 4.4 mm‑long screws
    • Two 4.8 mm‑long screws
    • Two 10.7 mm‑long screws
  29. Meta Quest 2 Screen and Lens Assembly Replacement: stap 29, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement: stap 29, afbeelding 2 van 2
    • Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
  30. Meta Quest 2 Screen and Lens Assembly Replacement: stap 30, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement: stap 30, afbeelding 2 van 2
    • Use tweezers to unclip the antenna cable from its metal clip.
  31. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the front antenna assembly: stap 31, afbeelding 1 van 1
    • Remove the front antenna assembly.
  32. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the fan: stap 32, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the fan: stap 32, afbeelding 2 van 2
    • Use tweezers to grab the fan connector and carefully slide it out of its socket.
  33. Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the LED flex cable: stap 33, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the LED flex cable: stap 33, afbeelding 2 van 2
    • Use the point of an opening pick to loosen the adhesive securing the LED flex cable from the top of the fan assembly.
  34. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the fan assembly: stap 34, afbeelding 1 van 1
    • Remove the two screws securing the fan assembly to the headset:
    • One 4.4 mm‑long Phillips screw
    • One 3.6 mm‑long Torx T2 screw
  35. Meta Quest 2 Screen and Lens Assembly Replacement: stap 35, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 35, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 35, afbeelding 3 van 3
    • Lift the fan assembly and remove it.
  36. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the heat sink: stap 36, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the four 2.3 mm‑long screws securing the heat sink to the motherboard.
  37. Meta Quest 2 Screen and Lens Assembly Replacement: stap 37, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement: stap 37, afbeelding 2 van 2
    iFixit Thermal Putty
    $9.95
    • Use your fingers to lift the heat sink and remove it.
    • You may feel a bit of resistance. This is normal since the midframe is slightly bonded to the heat sink with thermal paste.
    • You can reuse the thermal paste if you keep it clean. Otherwise, use a spudger to scrape off the old paste and apply a small amount of thermal putty or viscous thermal compound (such as K5 Pro) to the processor.
  38. Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: stap 38, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: stap 38, afbeelding 2 van 2
    • During reassembly, stop here and check if these twelve connectors are properly connected to the motherboard:
    • Two speaker connectors
    • Seven ZIF connectors
    • Two press connectors
    • One antenna connector
    • There are additional connectors on the motherboard, but they shouldn't be connected at this point.
  39. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the speaker connectors: stap 39, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the speaker connectors: stap 39, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the speaker connectors: stap 39, afbeelding 3 van 3
    • Use tweezers to grip the left speaker cables at the base of their motherboard connector.
    • Lift the connector gently straight up to disconnect it.
    • During reassembly, use the flat end of a spudger to press the speaker cable into the rubber holding clip.
  40. Meta Quest 2 Screen and Lens Assembly Replacement: stap 40, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 40, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 40, afbeelding 3 van 3
    • Repeat the disconnection procedure for the right speaker connector.
  41. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the ZIF socket flex cables: stap 41, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the ZIF socket flex cables: stap 41, afbeelding 2 van 2
    • Use tweezers to gently peel the black tape covering the two top flex cables.
    • Set the tape aside to be reused during reassembly.
  42. Meta Quest 2 Screen and Lens Assembly Replacement: stap 42, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 42, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 42, afbeelding 3 van 3
    • Use a clean fingernail or a spudger to pry up the lock tab securing the top left camera cable.
  43. Meta Quest 2 Screen and Lens Assembly Replacement: stap 43, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement: stap 43, afbeelding 2 van 2
    • Grasp the top left camera cable with tweezers and slide it out of its ZIF connector.
  44. Meta Quest 2 Screen and Lens Assembly Replacement: stap 44, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement: stap 44, afbeelding 2 van 2
    • Move counter-clockwise around the motherboard and disconnect the remaining six ZIF connectors:
    • Power button and LED board
    • Bottom left camera
    • Bottom right camera
    • Top right camera
    • Face sensor interconnect cable
    • Indicator LED cable
  45. Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the press connectors: stap 45, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the press connectors: stap 45, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Disconnect the press connectors: stap 45, afbeelding 3 van 3
    • Use a spudger to pry up and disconnect the display cable.
  46. Meta Quest 2 Screen and Lens Assembly Replacement: stap 46, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 46, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 46, afbeelding 3 van 3
    • Use a spudger to pry up and disconnect the USB‑C and headphone jack cable.
  47. Meta Quest 2 Screen and Lens Assembly Replacement: stap 47, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 47, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 47, afbeelding 3 van 3
    • Insert one arm of a pair of tweezers under the metal neck of the side antenna cable.
  48. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the motherboard: stap 48, afbeelding 1 van 1
    • Remove the five screws securing the motherboard to the headset:
    • Four 3.8 mm‑long Phillips screws
    • One 6 mm‑long 3.5 mm hex standoff screw
  49. Meta Quest 2 Screen and Lens Assembly Replacement: stap 49, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement: stap 49, afbeelding 2 van 2
    • At this point, the motherboard should be loose, with some thermal paste sticking it to the headset.
    • Use a spudger to pry up and separate the motherboard from the headset.
    • If it feels like the motherboard is caught on something, check that all the cables are disconnected from it.
  50. Meta Quest 2 Screen and Lens Assembly Replacement: stap 50, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement: stap 50, afbeelding 2 van 2
    $9.95
    • Remove the motherboard.
  51. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the camera covers: stap 51, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the camera covers: stap 51, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the camera covers: stap 51, afbeelding 3 van 3
    • Use your fingers or tweezers to peel and remove the two camera covers from the top cameras.
    • During reassembly, align the cutouts on the camera covers to their respective pegs on the headset.
    • The camera covers have different alignment cutouts and aren't interchangeable.
  52. Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the screen and lens assembly: stap 52, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement, Loosen the screen and lens assembly: stap 52, afbeelding 2 van 2
    • Peel and remove the black tape covering the antenna cable.
    • Set this tape aside to be reused during reassembly.
  53. Meta Quest 2 Screen and Lens Assembly Replacement: stap 53, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 53, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 53, afbeelding 3 van 3
    • Use tweezers to lift and unclip the black antenna cable from the metal grounding clips.
  54. Meta Quest 2 Screen and Lens Assembly Replacement: stap 54, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 54, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 54, afbeelding 3 van 3
    • Use a spudger to pry up the black lock tab securing the left microphone flex cable to the left interconnect cable.
    • Use your fingers or tweezers to slide the microphone cable out of the ZIF connector.
  55. Meta Quest 2 Screen and Lens Assembly Replacement: stap 55, afbeelding 1 van 1
    • Repeat the procedure to disconnect the right microphone cable.
  56. Meta Quest 2 Screen and Lens Assembly Replacement: stap 56, afbeelding 1 van 2 Meta Quest 2 Screen and Lens Assembly Replacement: stap 56, afbeelding 2 van 2
    • Slide the point of an opening pick underneath the battery flex cable to loosen the adhesive securing it from the headset.
  57. Meta Quest 2 Screen and Lens Assembly Replacement: stap 57, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 57, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement: stap 57, afbeelding 3 van 3
    • Some interconnect cables have been removed in the following images for clarity purposes. You don't have to remove them as part of the procedure.
    • Use a Phillips screwdriver to remove the four screws securing the screen and lens assembly to the frame:
    • Two 6.5 mm‑long screws
    • Two 7.7 mm‑long screws
  58. Meta Quest 2 Screen and Lens Assembly Replacement, Remove the screen and frame assembly: stap 58, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the screen and frame assembly: stap 58, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Remove the screen and frame assembly: stap 58, afbeelding 3 van 3
    • Grasp the screen and lens assembly with your fingers.
    • Slowly lift and separate the assembly from the outer shell, taking care to reposition any cables that get in the way.
    • Remove the screen and lens assembly.
  59. Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: stap 59, afbeelding 1 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: stap 59, afbeelding 2 van 3 Meta Quest 2 Screen and Lens Assembly Replacement, Reassembly note: stap 59, afbeelding 3 van 3
    • During reassembly, be careful not to trap the twelve cables as you insert the lens assembly into the outer shell:
    • Three cables along the top edge—two flex cables and one LED flex cable
    • Two cables in the top right corner—the battery connector and an antenna cable
    • Two cables along the right edge—an antenna cable and a wide flex cable
    • Two flex cables along the bottom edge
    • Three cables along the left edge—one antenna cable, one flex cable, and one speaker cable
    • You can use a rubber band to help secure the cables out of the way.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Arthur Shi
313.794 Reputatie
729 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.781 handleidingen geschreven
5Gids Commentaar
안녕하세요~
Meta Quest 2에 단열소재가 적용되어 있는지 문의 드립니다.
단열소재가 있다면 어느정도의 size인지 알고 싶습니다.
답변 부탁 드립니다.
박성철 - Antwoord
I had mine outside for less then a minute and i had a long yellow line Across the screen and i know it would be cheaper to fix it yourself and you having a step by step instructions on how to fix it is the absolute best thing i have seen a console developer do so you doing this probably super helpful to so many people Thank you
Anthony Dugan - Antwoord
If it doesn’t bother you too much, wait until you need to fix something else(i. e. the battery) and replace the screen with it. If it is a big line, then consider replacing it.
Dane Elliott-Dyson -
Hello, i need to replace my lcd 'cause sun burned it, whats the name of the "glue" that holds the lcd to his frame?
Felipe (DonF) - Antwoord
I followed every step, but now my controllers won't connect and they keep buzzing. the quest doesn't track my movements neither. I performed a factory reset, and now I only have sound. I only see an image when I try to turn it off, but the images sticks in front of me the pointer doesn't move. I double-checked all internal connections, and everything appears to be correctly connected. Does someone know the problem? Thanks!
Denis Scheldewaert - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 118
Afgelopen 30 dagen: 494
Altijd: 8,551
