Ga door naar hoofdinhoud
Meta Quest 2 Controller Front Trigger Replacement
Wat je nodig hebt
  1. Meta Quest 2 Controller Front Trigger Replacement, Remove the battery cover: stap 1, afbeelding 1 van 3 Meta Quest 2 Controller Front Trigger Replacement, Remove the battery cover: stap 1, afbeelding 2 van 3 Meta Quest 2 Controller Front Trigger Replacement, Remove the battery cover: stap 1, afbeelding 3 van 3
    • Use your fingers to slide the battery cover down towards the strap end of the controller.
    • Remove the battery cover.
    • If you're taking the controller apart for repairs, remove the batteries in the controller.
    Vraag FixBot
  2. Meta Quest 2 Controller Front Trigger Replacement, Remove the wrist strap: stap 2, afbeelding 1 van 2 Meta Quest 2 Controller Front Trigger Replacement, Remove the wrist strap: stap 2, afbeelding 2 van 2
    • Use your fingers to grasp the wrist strap near the anchor peg.
    • Lift the wrist strap anchor peg straight out of its recess.
    • Remove the wrist strap.
    Vraag FixBot
  3. Meta Quest 2 Controller Front Trigger Replacement, Loosen the faceplate adhesive: stap 3, afbeelding 1 van 1
    • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
    Vraag FixBot
  4. Meta Quest 2 Controller Front Trigger Replacement, Loosen the controller faceplate: stap 4, afbeelding 1 van 3 Meta Quest 2 Controller Front Trigger Replacement, Loosen the controller faceplate: stap 4, afbeelding 2 van 3 Meta Quest 2 Controller Front Trigger Replacement, Loosen the controller faceplate: stap 4, afbeelding 3 van 3
    • The controller faceplate is secured with adhesive and three friction pegs.
    • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
    • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
    • Slide the opening tool to the base of the ring shell to loosen the adhesive.
    Vraag FixBot
  5. Meta Quest 2 Controller Front Trigger Replacement: stap 5, afbeelding 1 van 2 Meta Quest 2 Controller Front Trigger Replacement: stap 5, afbeelding 2 van 2
    • Use an opening tool to pry up on the seam to loosen the first friction peg.
    Vraag FixBot
  6. Meta Quest 2 Controller Front Trigger Replacement: stap 6, afbeelding 1 van 2 Meta Quest 2 Controller Front Trigger Replacement: stap 6, afbeelding 2 van 2
    • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
    • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
    Vraag FixBot
  7. Meta Quest 2 Controller Front Trigger Replacement, Remove the faceplate: stap 7, afbeelding 1 van 3 Meta Quest 2 Controller Front Trigger Replacement, Remove the faceplate: stap 7, afbeelding 2 van 3 Meta Quest 2 Controller Front Trigger Replacement, Remove the faceplate: stap 7, afbeelding 3 van 3
    • Remove the controller faceplate.
    • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
    Vraag FixBot
  8. Meta Quest 2 Controller Front Trigger Replacement, Loosen the controller ring shell: stap 8, afbeelding 1 van 2 Meta Quest 2 Controller Front Trigger Replacement, Loosen the controller ring shell: stap 8, afbeelding 2 van 2
    • Use a Torx T5 driver to remove the four screws securing the controller ring shell to the controller:
    • Two 4.7 mm‑long screws
    • Two 5.9 mm‑long screws
    Vraag FixBot
  9. Meta Quest 2 Controller Front Trigger Replacement: stap 9, afbeelding 1 van 2 Meta Quest 2 Controller Front Trigger Replacement: stap 9, afbeelding 2 van 2
    • Press the point of a spudger firmly against the white alignment square to release the ring shell.
    Vraag FixBot
  10. Meta Quest 2 Controller Front Trigger Replacement, Remove the controller ring shell: stap 10, afbeelding 1 van 3 Meta Quest 2 Controller Front Trigger Replacement, Remove the controller ring shell: stap 10, afbeelding 2 van 3 Meta Quest 2 Controller Front Trigger Replacement, Remove the controller ring shell: stap 10, afbeelding 3 van 3
    • Use your fingers to grab the end of the ring shell that doesn’t have the white alignment square.
    • Gently lift the ring shell up and away from the controller to unclip it from the controller.
    • Remove the controller ring shell.
    Vraag FixBot
  11. Meta Quest 2 Controller Front Trigger Replacement, Loosen the side shell: stap 11, afbeelding 1 van 2 Meta Quest 2 Controller Front Trigger Replacement, Loosen the side shell: stap 11, afbeelding 2 van 2
    • Use a Torx T5 driver to remove the five screws:
    • One 11.5 mm‑long screw
    • Three 5.9 mm‑long screws
    • One 18.2 mm‑long screw
    Vraag FixBot
  12. Meta Quest 2 Controller Front Trigger Replacement, Remove the battery label: stap 12, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers and your fingers to peel the battery information label out from the battery compartment.
    • If you want to reuse this sticker, be careful not to tear it. If it’s difficult to peel, apply a heated iOpener to it for a minute to soften the label adhesive.
    Vraag FixBot
  13. Meta Quest 2 Controller Front Trigger Replacement, Loosen the side shell: stap 13, afbeelding 1 van 2 Meta Quest 2 Controller Front Trigger Replacement, Loosen the side shell: stap 13, afbeelding 2 van 2
    • Use a Torx T5 driver to remove the four 5.9 mm‑long screws securing the side shell to the controller:
    • Three screws inside the battery compartment
    • One screw near the corner of the battery compartment
    Vraag FixBot
  14. Meta Quest 2 Controller Front Trigger Replacement: stap 14, afbeelding 1 van 2 Meta Quest 2 Controller Front Trigger Replacement: stap 14, afbeelding 2 van 2
    • Pull the bottom of the side shell slightly away from the controller to loosen the shell.
    • You may hear a few clicks as the clips release. This is normal.
    Vraag FixBot
  15. Meta Quest 2 Controller Front Trigger Replacement: stap 15, afbeelding 1 van 2 Meta Quest 2 Controller Front Trigger Replacement: stap 15, afbeelding 2 van 2
    • Part of the side shell is looped around a screw post. In this step, you’ll spread the screw post apart enough to slip the shell out.
    • Insert the flat end of a spudger into the gap between the controller ring and the front shell.
    • The front shell is the plastic frame part below the front trigger.
    • Twist the spudger to widen the gap between the front shell and the controller.
    • Position the spudger so that it can stay in place without you holding the tool.
    Vraag FixBot
  16. Meta Quest 2 Controller Front Trigger Replacement, Remove the side shell: stap 16, afbeelding 1 van 3 Meta Quest 2 Controller Front Trigger Replacement, Remove the side shell: stap 16, afbeelding 2 van 3 Meta Quest 2 Controller Front Trigger Replacement, Remove the side shell: stap 16, afbeelding 3 van 3
    • Guide the looped part of the side shell through the screw post gap.
    • Remove the side shell.
    Vraag FixBot
  17. Meta Quest 2 Controller Front Trigger Replacement, Reassembly note: stap 17, afbeelding 1 van 3 Meta Quest 2 Controller Front Trigger Replacement, Reassembly note: stap 17, afbeelding 2 van 3 Meta Quest 2 Controller Front Trigger Replacement, Reassembly note: stap 17, afbeelding 3 van 3
    • During reassembly:
    • Spread the screw post wide enough to loop the side shell back around it.
    • Be careful not to pinch the antenna cable or the tracking flex cable as you reposition the side shell.
    Vraag FixBot
  18. Meta Quest 2 Controller Front Trigger Replacement, Remove the Controller Front Shell: stap 18, afbeelding 1 van 1
    • Use a spudger or an opening pick to gently pry the shell from the battery compartment side first.
    • Once it pops open, turn the controller over to remove the front shell.
    • If you have trouble, move to the next step.
    Vraag FixBot
  19. Meta Quest 2 Controller Front Trigger Replacement: stap 19, afbeelding 1 van 3 Meta Quest 2 Controller Front Trigger Replacement: stap 19, afbeelding 2 van 3 Meta Quest 2 Controller Front Trigger Replacement: stap 19, afbeelding 3 van 3
    • If you successfully removed the front shell, skip this step.
    • Grasp the front shell near the bottom of the controller.
    • Lift and pull the bottom edge of the front shell outwards slightly to clear the plastic alignment peg.
    • The alignment peg breaks easily. Make sure you lift the shell enough to clear it.
    Vraag FixBot
  20. Meta Quest 2 Controller Front Trigger Replacement: stap 20, afbeelding 1 van 2 Meta Quest 2 Controller Front Trigger Replacement: stap 20, afbeelding 2 van 2
    • Pull the front shell away from the controller and remove it.
    Vraag FixBot
  21. Meta Quest 2 Controller Front Trigger Replacement, Remove the front trigger pin: stap 21, afbeelding 1 van 3 Meta Quest 2 Controller Front Trigger Replacement, Remove the front trigger pin: stap 21, afbeelding 2 van 3 Meta Quest 2 Controller Front Trigger Replacement, Remove the front trigger pin: stap 21, afbeelding 3 van 3
    • Use a driver bit (such as the Torx T5) or the point of a spudger to push the front trigger pin out from the side shown. Pushing from the opposite side can cause the pin to rip the sensor cable.
    • For better reach, you can also use a straightened paper clip or the point of your tweezers.
    Vraag FixBot
  22. Meta Quest 2 Controller Front Trigger Replacement: stap 22, afbeelding 1 van 1
    • Hold the front trigger with your finger to prevent the trigger from flying out.
    • Use tweezers or your fingers to pull the trigger pin out.
    Vraag FixBot
  23. Meta Quest 2 Controller Front Trigger Replacement, Remove the front trigger: stap 23, afbeelding 1 van 2 Meta Quest 2 Controller Front Trigger Replacement, Remove the front trigger: stap 23, afbeelding 2 van 2
    Vraag FixBot
Conclusie
Arthur Shi
335.723 Reputatie
848 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
25.707 handleidingen geschreven
2Gids Commentaar
Mi gatillo anda pero no reconoce el solo apoyar del dedo.
Lean - Antwoord Deel
Me ha pasado lo mismo, no encuentro motivo ni solución.
Vicente Corbí - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 45
Afgelopen 30 dagen: 206
Altijd: 5,437
