Ga door naar hoofdinhoud
Magic Bullet MB1001B Activator Replacement
Aubree Duran
Aubree Duran en 4 andere bijdragers
Voor het laatst geüpdatet op January 9, 2024
20 - 30 minuten
Gemiddeld
Are you having trouble getting your Magic Bullet to turn on? Are the plastic activator tabs on your Magic Bullet broken off? This guide will help you replace the activators.
Wat je nodig hebt
Gereedschap
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Magic Bullet MB1001B Activator Replacement, Base Gear: stap 1, afbeelding 1 van 3 Magic Bullet MB1001B Activator Replacement, Base Gear: stap 1, afbeelding 2 van 3 Magic Bullet MB1001B Activator Replacement, Base Gear: stap 1, afbeelding 3 van 3
    • Use pliers to grip the gear inside of the top of the device.
    • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
    • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
    • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
    Can you replace the base gear in a Mini Bullet? I am having a hard time unscrewing it.
    Margaret Bellanger - Antwoord
  2. Magic Bullet MB1001B Activator Replacement, Casing: stap 2, afbeelding 1 van 1
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  3. Magic Bullet MB1001B Activator Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  4. Magic Bullet MB1001B Activator Replacement: stap 4, afbeelding 1 van 1
    • Remove the black base plate.
  5. Magic Bullet MB1001B Activator Replacement: stap 5, afbeelding 1 van 1
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  6. Magic Bullet MB1001B Activator Replacement: stap 6, afbeelding 1 van 1
    • Remove the white plastic cable guide.
  7. Magic Bullet MB1001B Activator Replacement: stap 7, afbeelding 1 van 1
    • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
  8. Magic Bullet MB1001B Activator Replacement: stap 8, afbeelding 1 van 1
    • Remove the black base.
  9. Magic Bullet MB1001B Activator Replacement: stap 9, afbeelding 1 van 1
    • Remove the three white rubber spacers with the spudger.
    White rubber spacer is broke from where to get one in colombon
    anonymous 1603 - Antwoord
  10. Magic Bullet MB1001B Activator Replacement: stap 10, afbeelding 1 van 1
    • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
    How is called the cover held by the 3 screws? Can be bought somewhere?
    Nicolas All - Antwoord
    will U give me feedback? If U have a part # will be great!
    Mine is broken, the rest is perfect! Thanks!
  11. Magic Bullet MB1001B Activator Replacement: stap 11, afbeelding 1 van 1
    • Remove the motor.
  12. Magic Bullet MB1001B Activator Replacement, Activator: stap 12, afbeelding 1 van 2 Magic Bullet MB1001B Activator Replacement, Activator: stap 12, afbeelding 2 van 2
    • Wedge a flathead screwdriver in between the casing and white plastic activator.
    • Pry the white plastic activators from the casing as needed.
    Do you know of anywhere to just buy the activator part for this machine? Thanks
    Izzi - Antwoord
    Where can I buy the “white plastic activators”?
    Erick Mata-Montero - Antwoord
Conclusie
3 andere personen hebben deze handleiding voltooid.
Aubree Duran
387 Reputatie
1 Handleiding geschreven
Cal Poly, Team 12-13, Maness Fall 2015 Lid van Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Leden
8 handleidingen geschreven
4Gids Commentaar
You gotta be kidding me?
marcomolinero72 - Antwoord
Right. Steps on how to fix their faulty machine. And worse. Selling you the tools to do it for only 29.99!
Del - Antwoord
Where would you get replacement activators or spring beneath these? How much would that cost?
Spartan 1293 - Antwoord
Oh, my gosh! I’ll just throw this thing away and use my blender!
txberta - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 71
Altijd: 9,209
