Ga door naar hoofdinhoud
MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement
Andrew Optimus Goldheart
Andrew Optimus Goldheart en 5 andere bijdragers
Voor het laatst geüpdatet op February 1, 2021
30 minuten - 2 uren
Gemiddeld
Replace a faulty fan to keep things cool.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
  1. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Three 13.5 mm (14.1 mm) Phillips screws.
    • Seven 3 mm Phillips screws.
    • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
  2. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: stap 2, afbeelding 1 van 1
    • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
  3. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement, Battery Connector: stap 3, afbeelding 1 van 2 MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement, Battery Connector: stap 3, afbeelding 2 van 2
    • For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary but is recommended as it prevents any accidental shorting of electronics on the motherboard. If you do not disconnect the battery connector, please be careful as parts of the motherboard might be electrified.
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
  4. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: stap 4, afbeelding 1 van 1
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
  5. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement, Left Fan: stap 5, afbeelding 1 van 1
    • Remove the following three screws securing the left fan to the logic board:
    • Two 3.5 mm T6 Torx screws.
    • One 4.2 mm T6 Torx screw.
  6. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: stap 6, afbeelding 1 van 3 MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: stap 6, afbeelding 2 van 3 MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: stap 6, afbeelding 3 van 3
    • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
    • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
    • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket.
    • The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
  7. MacBook Pro 15" Unibody Mid 2012 Left Fan Replacement: stap 7, afbeelding 1 van 1
    • Lift the left fan out of the upper case.
Conclusie
47 andere personen hebben deze handleiding voltooid.
508.631 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.418 handleidingen geschreven
3 opmerkingen
Are you sure that’s the left fan and not the right ?
If you click on the buy these parts” link it shows a picture of a different fan, the one on the other side of the MBP.
Would be nice if you could clear this up.
Thank you.
Konstantinos Bonotis - Antwoord
Yes its the left fan when you are typing on the Mac & that is what it’s called. When you replace it however it’s on the RHS of the upside down Mac with the motherboard exposed.
Stephen Fry - Antwoord
after cleaning the fans from dust, my left fan is making constantly noise. it’s not loud but it is annoying by time. can i fix this or is it because the fan is damaged?
butch coolidge - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 45
Altijd: 18,608
