Ga door naar hoofdinhoud
MacBook Air 11" Mid 2012 I/O Board Cable Replacement
Wat je nodig hebt
  1. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Lower Case: stap 1, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2012 I/O Board Cable Replacement: stap 2, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Battery: stap 3, afbeelding 1 van 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement, Battery: stap 3, afbeelding 2 van 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Mid 2012 I/O Board Cable Replacement, I/O Board Cable: stap 4, afbeelding 1 van 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement, I/O Board Cable: stap 4, afbeelding 2 van 2
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  5. MacBook Air 11" Mid 2012 I/O Board Cable Replacement: stap 5, afbeelding 1 van 2 MacBook Air 11" Mid 2012 I/O Board Cable Replacement: stap 5, afbeelding 2 van 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Andrew Optimus Goldheart
514.302 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
124 Leden
25.107 handleidingen geschreven
1Gids Commentaar
You only show the basic part of the removal. You do not show how to actually remove that board. You should have shown more steps.
Steven Pierce - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 40
Afgelopen 30 dagen: 1,980
Altijd: 21,406
