Ga door naar hoofdinhoud
Mac Studio 2023 Ethernet Board Replacement
Wat je nodig hebt
  1. Mac Studio 2023 Ethernet Board Replacement, Prepare your Mac Studio for disassembly: stap 1, afbeelding 1 van 3 Mac Studio 2023 Ethernet Board Replacement, Prepare your Mac Studio for disassembly: stap 1, afbeelding 2 van 3 Mac Studio 2023 Ethernet Board Replacement, Prepare your Mac Studio for disassembly: stap 1, afbeelding 3 van 3
    • Completely shut down your Mac Studio.
    • Unplug all cables from your device.
  2. Mac Studio 2023 Ethernet Board Replacement, Flip your Mac Studio over: stap 2, afbeelding 1 van 1
    • Flip your Mac Studio over and lay it down so the bottom faces up and the SD card slot and two front USB‑C ports are facing you.
  3. Mac Studio 2023 Ethernet Board Replacement, Heat the bottom cover screw pad: stap 3, afbeelding 1 van 3 Mac Studio 2023 Ethernet Board Replacement, Heat the bottom cover screw pad: stap 3, afbeelding 2 van 3 Mac Studio 2023 Ethernet Board Replacement, Heat the bottom cover screw pad: stap 3, afbeelding 3 van 3
    • Adhesive strips secure the bottom cover screw pad.
    • Heat an iOpener and lay it over one of the bottom cover screws for two minutes to soften the adhesive near the screw—this is where you'll insert a spudger in the next step.
    • You can also use a hair dryer or heat gun, but be careful as extreme heat will warp the pad.
  4. Mac Studio 2023 Ethernet Board Replacement, Lift a section of bottom cover screw pad: stap 4, afbeelding 1 van 3 Mac Studio 2023 Ethernet Board Replacement, Lift a section of bottom cover screw pad: stap 4, afbeelding 2 van 3 Mac Studio 2023 Ethernet Board Replacement, Lift a section of bottom cover screw pad: stap 4, afbeelding 3 van 3
    • Insert the point of a spudger under the pad's inner edge, near the screw you applied heat to in the previous step.
    • This may take some force. If you're having trouble, apply more heat and try again.
    • Use the spudger to lift the pad and separate the adhesive.
  5. Mac Studio 2023 Ethernet Board Replacement, Separate the remaining adhesive: stap 5, afbeelding 1 van 3 Mac Studio 2023 Ethernet Board Replacement, Separate the remaining adhesive: stap 5, afbeelding 2 van 3 Mac Studio 2023 Ethernet Board Replacement, Separate the remaining adhesive: stap 5, afbeelding 3 van 3
    • Insert the flat end of a spudger under the pad.
    • Slide the spudger under the entire pad to separate the remaining adhesive.
  6. Mac Studio 2023 Ethernet Board Replacement, Remove the bottom cover screw pad: stap 6, afbeelding 1 van 1
    • Remove the bottom cover screw pad.
  7. Mac Studio 2023 Ethernet Board Replacement, Reassembly information: stap 7, afbeelding 1 van 3 Mac Studio 2023 Ethernet Board Replacement, Reassembly information: stap 7, afbeelding 2 van 3 Mac Studio 2023 Ethernet Board Replacement, Reassembly information: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Tesa 61395 Tape
    $2.99
    • During reassembly:
    • If the adhesive strips are still sticky, you can reuse them.
    • If you're applying new adhesive:
    • Use the flat end of a spudger and your fingers to scrape up and remove the old adhesive strips.
    • Use isopropyl alcohol and a microfiber cloth to remove the old adhesive residue.
    • If you don't have replacement adhesive, you can use strips of thin, double-sided tape 2–3 mm wide.
    • Apply the new adhesive strips to the bottom cover and remove their liners.
    • Firmly press the bottom cover screw pad into its recess to secure it.
  8. Mac Studio 2023 Ethernet Board Replacement, Remove the bottom cover screws: stap 8, afbeelding 1 van 2 Mac Studio 2023 Ethernet Board Replacement, Remove the bottom cover screws: stap 8, afbeelding 2 van 2
    FixMat
    $31.41
    • While the Mac Studio uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T10 Torx screwdriver to remove the four 8 mm‑long screws securing the bottom cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came.
  9. Mac Studio 2023 Ethernet Board Replacement, Remove the bottom cover: stap 9, afbeelding 1 van 3 Mac Studio 2023 Ethernet Board Replacement, Remove the bottom cover: stap 9, afbeelding 2 van 3 Mac Studio 2023 Ethernet Board Replacement, Remove the bottom cover: stap 9, afbeelding 3 van 3
    • Insert the point of a spudger in one of the bottom cover's ventilation holes and lift the cover until you can grab it with your fingers.
    • Remove the bottom cover.
    • To orient the bottom cover, align the Kensington lock cutout in the top left corner with the corresponding one on the internal frame.
  10. Mac Studio 2023 Ethernet Board Replacement, Remove the power supply screws: stap 10, afbeelding 1 van 2 Mac Studio 2023 Ethernet Board Replacement, Remove the power supply screws: stap 10, afbeelding 2 van 2
    • Use a T10 Torx screwdriver to remove the six screws securing the power supply:
    • Four 6 mm‑long screws
    • Two 7 mm‑long screws with washers
    • You may need to remove a sticker to access these screws. If you do, save it for reassembly.
  11. Mac Studio 2023 Ethernet Board Replacement, Reposition your Mac Studio: stap 11, afbeelding 1 van 1
    • Flip your Mac Studio around so the rear ports are facing you.
  12. Mac Studio 2023 Ethernet Board Replacement, Disconnect the power cord port cable: stap 12, afbeelding 1 van 3 Mac Studio 2023 Ethernet Board Replacement, Disconnect the power cord port cable: stap 12, afbeelding 2 van 3 Mac Studio 2023 Ethernet Board Replacement, Disconnect the power cord port cable: stap 12, afbeelding 3 van 3
    • A tight plastic latch secures the power cord port cable.
    • Firmly hold the power supply with one hand and lift up the edge near the power cord port.
    • With your free hand, pinch the head of the power cord port connector to unclip it and pull straight down to disconnect the cable.
  13. Mac Studio 2023 Ethernet Board Replacement, Tilt up the power supply: stap 13, afbeelding 1 van 1
    • Only grab the power supply by its edges. Various power components and capacitors are left exposed.
    • Carefully tilt the power supply away from the power cord port so it's at a 90-degree angle.
    • Be careful not to strain the cable that's still connected to the power supply.
    • Keep the power supply tilted up for the next step.
  14. Mac Studio 2023 Ethernet Board Replacement, Disconnect the power supply signal cable: stap 14, afbeelding 1 van 3 Mac Studio 2023 Ethernet Board Replacement, Disconnect the power supply signal cable: stap 14, afbeelding 2 van 3 Mac Studio 2023 Ethernet Board Replacement, Disconnect the power supply signal cable: stap 14, afbeelding 3 van 3
    • A delicate plastic clip secures the power supply signal cable.
    • With your free hand, pinch the head of the power supply connector to unclip it and pull straight away from the socket to disconnect the cable.
  15. Mac Studio 2023 Ethernet Board Replacement, Remove the power supply: stap 15, afbeelding 1 van 1
    • Remove the power supply.
  16. Mac Studio 2023 Ethernet Board Replacement, Reposition your Mac Studio: stap 16, afbeelding 1 van 1
    • Flip your Mac Studio around so the SD card reader and two front USB‑C ports are facing you.
  17. Mac Studio 2023 Ethernet Board Replacement, Remove the internal frame screws: stap 17, afbeelding 1 van 2 Mac Studio 2023 Ethernet Board Replacement, Remove the internal frame screws: stap 17, afbeelding 2 van 2
    • Use a T6 Torx screwdriver to remove the eight screws securing the internal frame:
    • Seven 5 mm‑long screws
    • One 4 mm‑long screw
  18. Mac Studio 2023 Ethernet Board Replacement, Remove the internal frame: stap 18, afbeelding 1 van 2 Mac Studio 2023 Ethernet Board Replacement, Remove the internal frame: stap 18, afbeelding 2 van 2
  19. Mac Studio 2023 Ethernet Board Replacement, Remove the ethernet board cable cover: stap 19, afbeelding 1 van 3 Mac Studio 2023 Ethernet Board Replacement, Remove the ethernet board cable cover: stap 19, afbeelding 2 van 3 Mac Studio 2023 Ethernet Board Replacement, Remove the ethernet board cable cover: stap 19, afbeelding 3 van 3
    • Use a T3 Torx screwdriver to remove the two 2 mm‑long screws securing the ethernet board cable cover.
    • Use tweezers or your fingers to remove the cover.
  20. Mac Studio 2023 Ethernet Board Replacement, Disconnect the ethernet board: stap 20, afbeelding 1 van 2 Mac Studio 2023 Ethernet Board Replacement, Disconnect the ethernet board: stap 20, afbeelding 2 van 2
    • Be very careful not to scrape off or damage any surface mounted components during this step.
    • Use a spudger to pry up and disconnect the ethernet board cable press connector from the logic board.
    • To reconnect press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  21. Mac Studio 2023 Ethernet Board Replacement, Reposition your Mac Studio: stap 21, afbeelding 1 van 1
    • Carefully stand up your Mac Studio so the SD card reader and two front USB-C ports are facing up.
  22. Mac Studio 2023 Ethernet Board Replacement, Remove the ethernet board cable: stap 22, afbeelding 1 van 3 Mac Studio 2023 Ethernet Board Replacement, Remove the ethernet board cable: stap 22, afbeelding 2 van 3 Mac Studio 2023 Ethernet Board Replacement, Remove the ethernet board cable: stap 22, afbeelding 3 van 3
    Flexible Extension
    $6.99
    • Use a T4 Torx screwdriver to remove the two 11 mm‑long screws securing the right side of the ethernet board and its cover.
    • These screws may be hard to access. If you can't insert your screwdriver properly, use a flexible extension to avoid stripping screws or damaging the logic board.
  23. Mac Studio 2023 Ethernet Board Replacement: stap 23, afbeelding 1 van 3 Mac Studio 2023 Ethernet Board Replacement: stap 23, afbeelding 2 van 3 Mac Studio 2023 Ethernet Board Replacement: stap 23, afbeelding 3 van 3
    • Insert the point of a spudger under the bottom right corner of the ethernet board press connector and lift up to disconnect it.
    • Don't pry against any surface mounted components.
    • Remove the cable.
  24. Mac Studio 2023 Ethernet Board Replacement, Remove the ethernet board screws: stap 24, afbeelding 1 van 2 Mac Studio 2023 Ethernet Board Replacement, Remove the ethernet board screws: stap 24, afbeelding 2 van 2
    Flexible Extension
    $6.99
    • Use a T6 Torx screwdriver to remove the two 20 mm‑long screws (with washers) securing the ethernet board.
    • Be careful not to lose the washers, as they can fall off easily.
  25. Mac Studio 2023 Ethernet Board Replacement, Remove the ethernet board: stap 25, afbeelding 1 van 2 Mac Studio 2023 Ethernet Board Replacement, Remove the ethernet board: stap 25, afbeelding 2 van 2
    • Lift the ethernet board out of its recess and remove it.
Conclusie
Spencer Day
149.628 Reputatie
995 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
23.626 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 34
Altijd: 442
