Ga door naar hoofdinhoud
Logitech MX Master Mouse Feet Replacement
Clay Eickemeyer
Clay Eickemeyer en 4 andere bijdragers
Voor het laatst geüpdatet op November 25, 2024
10 - 20 minuten
Eenvoudig
OEM-handleiding
Use this guide to replace worn-out or damaged feet (also known as skates, glides, slides, or pads) on your Logitech MX Master mouse.
While it’s possible to cleanly remove the feet, you may need replacements if one rips or separates from its adhesive pad.
Wat je nodig hebt
Reparatieset
Deze set bevat alle onderdelen en tools om deze handleiding te voltooien.
Onderdelen
Gereedschap
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Logitech MX Master Mouse Feet Replacement, Soften the mouse feet adhesive: stap 1, afbeelding 1 van 2 Logitech MX Master Mouse Feet Replacement, Soften the mouse feet adhesive: stap 1, afbeelding 2 van 2
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Apply a heated iOpener to the left and right mouse feet for about one minute each.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
    • The information sticker adhesive may soften during this step, but you don't need to remove it.
  2. Logitech MX Master Mouse Feet Replacement, Separate the left foot adhesive: stap 2, afbeelding 1 van 3 Logitech MX Master Mouse Feet Replacement, Separate the left foot adhesive: stap 2, afbeelding 2 van 3 Logitech MX Master Mouse Feet Replacement, Separate the left foot adhesive: stap 2, afbeelding 3 van 3
    • Insert an opening pick between the left foot and the lower case.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
  3. Logitech MX Master Mouse Feet Replacement, Remove the left mouse foot: stap 3, afbeelding 1 van 2 Logitech MX Master Mouse Feet Replacement, Remove the left mouse foot: stap 3, afbeelding 2 van 2
    • Peel up and remove the left mouse foot.
  4. Logitech MX Master Mouse Feet Replacement, Remove the right mouse foot: stap 4, afbeelding 1 van 3 Logitech MX Master Mouse Feet Replacement, Remove the right mouse foot: stap 4, afbeelding 2 van 3 Logitech MX Master Mouse Feet Replacement, Remove the right mouse foot: stap 4, afbeelding 3 van 3
    • Insert and slide your opening pick under the right foot to separate its adhesive.
    • Remove the right mouse foot.
  5. Logitech MX Master Mouse Feet Replacement, Soften the remaining mouse feet adhesive: stap 5, afbeelding 1 van 1
    • Apply a heated iOpener across the top and bottom mouse feet for one minute.
  6. Logitech MX Master Mouse Feet Replacement, Separate the top foot adhesive: stap 6, afbeelding 1 van 3 Logitech MX Master Mouse Feet Replacement, Separate the top foot adhesive: stap 6, afbeelding 2 van 3 Logitech MX Master Mouse Feet Replacement, Separate the top foot adhesive: stap 6, afbeelding 3 van 3
    • Insert an opening pick between the top foot and the lower case.
  7. Logitech MX Master Mouse Feet Replacement, Remove the top mouse foot: stap 7, afbeelding 1 van 2 Logitech MX Master Mouse Feet Replacement, Remove the top mouse foot: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use your fingers or a pair of tweezers to remove the top mouse foot.
  8. Logitech MX Master Mouse Feet Replacement, Remove the bottom mouse foot: stap 8, afbeelding 1 van 3 Logitech MX Master Mouse Feet Replacement, Remove the bottom mouse foot: stap 8, afbeelding 2 van 3 Logitech MX Master Mouse Feet Replacement, Remove the bottom mouse foot: stap 8, afbeelding 3 van 3
    • Insert and slide your opening pick under the bottom mouse foot to separate its adhesive.
    • Remove the bottom mouse foot.
  9. Logitech MX Master Mouse Feet Replacement, Reassembly information: stap 9, afbeelding 1 van 3 Logitech MX Master Mouse Feet Replacement, Reassembly information: stap 9, afbeelding 2 van 3 Logitech MX Master Mouse Feet Replacement, Reassembly information: stap 9, afbeelding 3 van 3
    • For installing new mouse feet or reusing your old ones:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free or microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
Conclusie
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Één andere persoon heeft deze handleiding voltooid.
Clay Eickemeyer
81.350 Reputatie
455 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
9 Leden
11.365 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 96
Afgelopen 30 dagen: 302
Altijd: 4,499
