Ga door naar hoofdinhoud
Logitech G Pro X Superlight Scroll Wheel Replacement
Zane
Zane en 5 andere bijdragers
Voor het laatst geüpdatet op October 20, 2024
50 minuten
Gemiddeld
A Logitech G Pro Superlight starts scrolling by itself. Not only does it become unusable but also extremely frustrating to the user. There may be problems like dust trapped inside, blocking the sensor from registering. It is very important to get this fixed because the scroll wheel is an important aspect of the mouse. Whether browsing or gaming it gives user many purposes of using it. This guide provides a solution by replacing the malfunctioning scroll wheel with a new one.
Caution: Turn off the mouse and disconnect the USB dongle connected to the PC before starting this guide.
  1. Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 1 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 2 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement, Scroll Wheel: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Mouse skates will be damaged during this process. Having a new pair of mouse skates is STRONGLY recommended.
    • Use tweezers to peel off the mouse skates on the underside of the mouse.
  2. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 2, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the six screws using a 1.6mm Phillips screwdriver on the top and bottom side of the mouse.
  3. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 3, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 3, afbeelding 2 van 2
    • Open the bottom shell with your hands.
    • Use caution, as wires are still intact.
    • The bottom shell should come off easily without applying any force.
  4. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 4, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the wires and cables in contact with the sensor's motherboard.
    • Pull and shake evenly on the cable to make sure cables are not strained. Avoid pulling heavily.
  5. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 5, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 5, afbeelding 2 van 2
    • Take out the battery located at the back of the mouse.
    • Flipping it upside down helps when removing it.
  6. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 6, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 6, afbeelding 2 van 2
    • Remove four screws at the bottom part of the mouse with a 1.6mm screwdriver.
  7. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 7, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 7, afbeelding 2 van 2
    • Carefully take out the left and right mouse buttons.
  8. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 8, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 8, afbeelding 2 van 2
    • Remove the four screws attached to the scroll wheel.
  9. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 9, afbeelding 1 van 2 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 9, afbeelding 2 van 2
    • Apply pressure and shake evenly to remove the attached cable.
    • The scroll wheel comes off easily without using too much pressure.
    • Insert the new scroll wheel and line up against the sensor.
  10. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 10, afbeelding 1 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 10, afbeelding 2 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 10, afbeelding 3 van 3
    • Reattach the cable.
    • Refasten the four screws.
  11. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 11, afbeelding 1 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 11, afbeelding 2 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 11, afbeelding 3 van 3
    • Use a pair of tweezers to reinsert the four screws at the bottom half of the mouse and tighten with a screwdriver.
    • Attach the battery back on the bottom half of the mouse.
    • Reattach the two cables.
  12. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 12, afbeelding 1 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 12, afbeelding 2 van 3 Logitech G Pro X Superlight Scroll Wheel Replacement: stap 12, afbeelding 3 van 3
    • Line up the bottom shell with the top shell and connect them together.
    • Reapply the four screws back onto the mouse.
  13. Logitech G Pro X Superlight Scroll Wheel Replacement: stap 13, afbeelding 1 van 1
    • Put on your new mouse skates.
    • Apply pressure so that they stick to the mouse, leaving no air gap.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Zane
307 Reputatie
1 Handleiding geschreven
York University, Team M-9, Allen Summer 2023 Lid van York University, Team M-9, Allen Summer 2023
YORK-ALLEN-SU23SMG9
2 Leden
7 handleidingen geschreven
5 opmerkingen
Thanks for publishing this!
Do you replace only plastic part of wheel or plastic wheel + PCB?
Where do you order new wheel?
Andriy Legayev - Antwoord
https://ausmodshop.com/products/modded-l... pricy, but they have full replacement pcbs with all the parts installed for you so you
Daniel G -
I don't think the soft black part is separable for the original wheel. Ordered an 'original' (or mostly original 🙂) wheel at one famous giant Chinese marketplace for 6 USD, item id 1005006217893341 - couldn't find any difference
V S -
Thanks for the guide. Didn't need a new scroll wheel, but the disassembly guide was great.
Uber Beast - Antwoord
Thanks for the guide. Some steps are not necessary if your purpose is just to change the wheel
V S - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 107
Afgelopen 7 dagen: 735
Afgelopen 30 dagen: 2,813
Altijd: 53,962
