Ga door naar hoofdinhoud
Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement
Yuanwei Chen
Yuanwei Chen en 4 andere bijdragers
Voor het laatst geüpdatet op December 27, 2024
2 - 5 minuten
Eenvoudig
Replacing the battery is often a simple and effective solution for resolving the issue of the device not powering on. If your Little Tikes Tobi 2 Interactive Karaoke Machine fails to respond or shows no signs of life, the batteries may be drained or improperly installed. To address this, you will need four new AA alkaline batteries—preferably from a reliable brand to ensure optimal performance and longevity.
Wat je nodig hebt
Onderdelen
Gereedschap
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove the single screw that is holding the cover to the battery compartment.
    • If the screw doesn’t come out right away, use a spudger to gently lift the edge of the battery compartment in the recessed area while continuing to unscrew it with your other hand.
    • Use a spudger to carefully pry off the battery cover.
  2. Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement: stap 2, afbeelding 1 van 2 Little Tikes Tobi 2 Interactive Karaoke Machine Battery Replacement: stap 2, afbeelding 2 van 2
    • To easily pop out a battery, use your thumb to push the battery from the flat side down toward the coil and pull the battery outward.
    • Remove all four batteries.
    • Take a new AA alkaline battery and position it in the correct orientation. Insert the flat side of the battery facing the coil first, then press the raised side down. Ensure this second battery is oriented in the opposite direction to the first. Continue replacing the batteries in an alternating pattern.
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Yuanwei Chen
185 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 5-4, Kershman Fall 2024 Lid van CSU Los Angeles, Team 5-4, Kershman Fall 2024
CSULA-KERSHMAN-F24S5G4
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 34
Altijd: 100
