Ga door naar hoofdinhoud
Leviton DW15S WiFi Light Switch Capacitors Replacement
Dan Dunham
Dan Dunham en een andere bijdrager
Voor het laatst geüpdatet op May 3, 2023
1 uur
Gemiddeld
Door de gemeenschap gemaakte handleiding
Vereist transcriptie
I show you how to tear down the DW15s WIFI switch and I show one potentially common problem with these devices. Many of these devices use cheap capacitors and when they start going bad they can cause all sorts of unexpected results. This is just one example of how to diagnose and repair them. Of Course there are many other things that can go wrong but this is probably the most likely problem when they act up.
Video overzicht
    • Take a look at this video for tear down and repair instructions.
Conclusie
Dan Dunham
3.477 Reputatie
30 handleidingen geschreven
2Gids Commentaar
Hi there. I actually opened mine up and the capacitors were 3.3 uf and 450volt. Weird
Kelly K - Antwoord
There are high voltage caps in there but those are not the ones that fail normally. You’re looking for low voltage high capacitance caps that are the electrolytic type and they will be larger and looks like a barrel.
Dan Dunham - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 304
