Ga door naar hoofdinhoud
Lenovo Yoga Book X90F Battery Replacement
Wat je nodig hebt
  1. Lenovo Yoga Book X90F Battery Replacement, Bottom Screen/Keyboard: stap 1, afbeelding 1 van 1
    • Turn off and power down the device before beginning this process. A heat gun or hair dryer will be suitable to heat the adhesive that holds down the screen. Apply heat to the entire surface area of the bottom screen.
    • New adhesive will be required when completing the steps in reverse order.
  2. Lenovo Yoga Book X90F Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo Yoga Book X90F Battery Replacement: stap 2, afbeelding 2 van 2
    • Once the adhesive has been heated up, take the iFixIt suction cup and lift in a corner. The screen should be separating from the adhesive here.
    • While the screen is lifted, insert the ifixit opening pick to help pry off the screen.
    • The screen may crack easily as it is thin and fragile.
    basically by this technique the screen WILL be cracked (as the images here show, and as I was actually expecting sadly). I wonder if there is a safer technique to remove the screen, even though it is too late for me now?
    Mark Rohde - Antwoord
    I also &&^&@@ up the screen following this guide. Too bad, the thing costs 160 euros.
    tanner85 - Antwoord
    This is barbaric work. The keyboard is broken at the edges. In other words, it's not just the battery that needs to be replaced 😁 It wasn't heated enough at the edges. You shouldn't tense up
    Ricsi Fusti - Antwoord
  3. Lenovo Yoga Book X90F Battery Replacement: stap 3, afbeelding 1 van 1
    • While the screen has been lifted, insert the plastic opening picks. Heat the adhesive and follow with the screen removal tool to ensure that you are not prying it apart with excessive force.
  4. Lenovo Yoga Book X90F Battery Replacement: stap 4, afbeelding 1 van 3 Lenovo Yoga Book X90F Battery Replacement: stap 4, afbeelding 2 van 3 Lenovo Yoga Book X90F Battery Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • After the screen has been opened, disconnect the ribbon connecting the bottom screen to the motherboard by gently pulling the ribbon with tweezers.
    • If there are black coverings on the tabs as shown in the second image, carefully remove them using a pair of tweezers.
    • You can find more information on Zero Insertion Force (ZIF) connectors on this guide.
  5. Lenovo Yoga Book X90F Battery Replacement: stap 5, afbeelding 1 van 1
    • Separate and remove the bottom screen from the device.
  6. Lenovo Yoga Book X90F Battery Replacement, Battery: stap 6, afbeelding 1 van 3 Lenovo Yoga Book X90F Battery Replacement, Battery: stap 6, afbeelding 2 van 3 Lenovo Yoga Book X90F Battery Replacement, Battery: stap 6, afbeelding 3 van 3
    • Using a JIS #0 screwdriver, remove the single 8 mm screw.
    • Disconnect the battery cable from the motherboard.
    there was a screw in this position in my tablet, but not connected to the ribbon in anyway. Also, it was an extremely soft screw, just ground away under the appropriate screwdriver!! so lucky it didn't need to be removed!
  7. Lenovo Yoga Book X90F Battery Replacement: stap 7, afbeelding 1 van 1
    • Use the opening pick to remove the two black strips on each side of the battery so the battery is cleared of any obstructions.
    Maybe it depends on the particular placement of the battery, but I can't see the need for this step unless the black strips have been very poorly placed.
  8. Lenovo Yoga Book X90F Battery Replacement: stap 8, afbeelding 1 van 2 Lenovo Yoga Book X90F Battery Replacement: stap 8, afbeelding 2 van 2
    • The battery is glued down to the frame of the computer.
    • Wedge the opening pick underneath the battery and work your around the battery.
  9. Lenovo Yoga Book X90F Battery Replacement: stap 9, afbeelding 1 van 1
    • Once the adhesive begins to unstick from the battery, remove the battery from the device.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Één andere persoon heeft deze handleiding voltooid.
Parker Mumaw
127 Reputatie
1 Handleiding geschreven
Clemson, Team 5-2, Hunter Fall 2021 Lid van Clemson, Team 5-2, Hunter Fall 2021
CLEM-HUNTER-F21S5G2
5 Leden
6 handleidingen geschreven
7 opmerkingen
Make a plan to replace the keyboard/second screen after installing a replacement battery.
How to calibrate the battery?
Janet Davidson - Antwoord
I like how the screen is broken in the pictures from step 1 to step 2. :P
emmerycheung - Antwoord
Thanks for the writeup! too bad the cost of replacement parts make this repair almost not worth the effort. =(
Jonathan Lin - Antwoord
Excellent but i find nowhere an explanation of how to reassembly, mainly how to adhere the keyboard glass surface to the base chasis. I mean, is still usable the same original adhesive heated in the first step or a two sides adhesive frame has to be placed after removing the old adhesive (or just aplying a sort of glue -¿wich one?-). I’ not sure I’ve made it clear, I hope yes. Thanks in advance.
Cesar - Antwoord
1) The original adhesive would be 100% unusable. You can use a double-sided red table from 5mm to 10mm. Rule of thumb for future repairs, put in the cover/screen/part and the chassis you want to glue together. Also, wear heat-resistant gloves and when you stick them together, reheat the areas and press and move your finger along the path of the tape to soften the glue and remove any imperfect bonding.
2) If tape is not your forte, you can use T8000 black/clear glue but be aware that you must be fast. This glue can dry in less than a minute! Also, you must be frugal with its use because it's very sticky and can make a mess.
3) Finally, and this is an ABSOLUTE MUST, if there are any cables, antennas, plastic covers, or flex cables in the path or near the areas where you need to put glue or tape, put Kapton tape on top before anything else.
George Cristodoulou -
For easier separation, when there is glass involved, you can use isopropyl alcohol. Put it in a small plastic bottle with a small opening, the best for this are medical bottles you can buy in a pharmacy and also put the tip of a syringe so you can have total control of the dosage you use and also you can put the liquid in tiny dosages along the path of the adhesive, effectively loosening the adhesive even further.
George Cristodoulou - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 160
Altijd: 8,507
