Wiki met studentenbijdrage
Een geweldig team van studenten van ons onderwijsprogramma heeft deze wiki gemaakt.
Short battery life
The Lenovo Yoga Book X90F battery has to be constantly plugged in.
Faulty Battery
If the laptop will operate only when the battery is plugged in, then the battery may be faulty. To check, unplug the power adapter and if the laptop dies quickly, then the battery is the faulty component. Replace the battery with this guide.
Battery Heavy Applications
The laptop may have a short battery life when unplugged due to applications running in the background or many applications being used at once. Gaming may also contribute to high battery usage. Either use less apps at once, or to ensure longer lasting battery life, use the power adapter to charge the battery.
How to fix "Insufficient storage available" message, or blue screening
Checking the Storage
If the laptop shows a message saying “Insufficient storage available”, then the storage may be full. The storage can be verified by clicking the folder at the bottom of the screen and clicking “This PC”, which will display the available storage. This task can also be done by clicking the Windows icon, then the Settings button. In Settings, select the System settings at the top and then find storage on the left side of the screen. This will also display the available storage.
- If Storage is Full
If the storage is full, then additional means may be required to add storage space. This can be done by adding an SD card into the slot on the side of the computer, or by adding a USB drive into one of the USB ports. A USB drive has a variety of storage options and can often have more storage than the hard drive. However, the USB drive can only be connected to the computer with the use of a USB adapter.
- If Storage is not Full
If the storage is not full, then the SSD may need to be replaced. Use this guide to replace the SSD.
Blue Screen
A blue screen is an indicator that the SSD will need to be replaced. The blue screen will cause an immediate restart. The blue screen often appears on startup, but it can occur at any point during operation of the PC. It also can occur during every startup without allowing login, which is a direct indicator of a faulty SSD. If possible, backup all files on the hard drive prior to replacement, then use this guide to replace the SSD.
Poor audio
The Lenovo Yoga Book X90F has poor audio quality.
Outdated Driver or Not Installed
If the laptop has poor audio quality through the speakers, then the driver may be outdated or not installed properly. To fix this, go to this website and install the driver with the most recent update. If this fails to work, continue troubleshooting with the next topic, Faulty Laptop Speaker.
If the Yoga Book is producing poor quality audio, then the speaker may be the faulty component. To check, try playing a type of audio through the laptop speakers and if there is little to no playback then the speaker is the faulty component. Replace the speaker with this guide.
Bottom Camera Will Not Register
The Lenovo Yoga Book X90F camera when the laptop is folded open is not registering.
Unresponsive Camera
If the camera takes several tries to work, is not turning on after opening the laptop or not registering when needing to take a picture, try to reinstall the driver. Lenovo has released a driver update for the camera which can be found through the following link here.
Faulty bottom camera
If the camera continues to fail after updating, it may be a faulty camera and can be replaced with the following guide.
Unresponsive Keyboard
The laptop’s bottom screen keyboard is unresponsive to touch.
Keyboard Not On
If the keyboard is unresponsive to the touch, it may not be initialized and will need to be done so. Use this guide for assistance on turning on the keyboard. If this does not resolve the issues, continue to the next troubleshooting topic.
Faulty Keyboard
After following the steps to check if the keyboard is on and this does not resolve the issue, the bottom screen may be the faulty component. Therefore, the screen and keyboard accessories will need to be replaced. To replace this, use this guide to resolve the issues.
0 opmerkingen
