Ga door naar hoofdinhoud
Lenovo ThinkPad T480 Internal Battery Replacement
Wat je nodig hebt
  1. Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: stap 1, afbeelding 1 van 2 Lenovo ThinkPad T480 Internal Battery Replacement, External Battery: stap 1, afbeelding 2 van 2
    • Disable the battery, power down, and unplug your device before you begin.
    • Flip the laptop over so the bottom of the device is showing.
  2. Lenovo ThinkPad T480 Internal Battery Replacement: stap 2, afbeelding 1 van 3 Lenovo ThinkPad T480 Internal Battery Replacement: stap 2, afbeelding 2 van 3 Lenovo ThinkPad T480 Internal Battery Replacement: stap 2, afbeelding 3 van 3
    • Using your fingers, slide the lock on each side of the battery to the unlocked position.
    • Remove the battery from the slot.
  3. Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: stap 3, afbeelding 1 van 2 Lenovo ThinkPad T480 Internal Battery Replacement, Back Cover: stap 3, afbeelding 2 van 2
    • Using the Phillips #1 screwdriver, loosen the six captive screws.
  4. Lenovo ThinkPad T480 Internal Battery Replacement: stap 4, afbeelding 1 van 3 Lenovo ThinkPad T480 Internal Battery Replacement: stap 4, afbeelding 2 van 3 Lenovo ThinkPad T480 Internal Battery Replacement: stap 4, afbeelding 3 van 3
    • Insert the blue plastic opening tool into the space between the lower case and the chassis.
    • Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
    • If it feels like the battery well portion of the back cover isn't loose, these clips may be holding the cover to the laptop. Use your opening tool to pry the clips loose and try removing the cover again.
    • Remove the back case.
  5. Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: stap 5, afbeelding 1 van 2 Lenovo ThinkPad T480 Internal Battery Replacement, Internal Battery: stap 5, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the two 4.6 mm screws that secure the internal battery to the frame.
  6. Lenovo ThinkPad T480 Internal Battery Replacement: stap 6, afbeelding 1 van 3 Lenovo ThinkPad T480 Internal Battery Replacement: stap 6, afbeelding 2 van 3 Lenovo ThinkPad T480 Internal Battery Replacement: stap 6, afbeelding 3 van 3
    • Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
  7. Lenovo ThinkPad T480 Internal Battery Replacement: stap 7, afbeelding 1 van 2 Lenovo ThinkPad T480 Internal Battery Replacement: stap 7, afbeelding 2 van 2
    • Lift the battery straight out of its recess and remove it.
    • If the battery is difficult to remove from the recess, use a nylon spudger to gently lift it on one edge, making it easier to grasp and remove by hand.
    • To prevent damage or potential fire, do not bend or flex the battery. Only use a plastic spudger and avoid any sharp tools that could puncture the battery.
Conclusie
10 andere personen hebben deze handleiding voltooid.
Sarah Westberg
29.609 Reputatie
71 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.545 handleidingen geschreven
7 opmerkingen
"What you need" contains a wrong part.
cumledomla - Antwoord
Hi @cumledomla, I've added the internal battery for this guide. Thanks for pointing that out! The external battery will show up in the "What you need" section because it's imported from the prerequisite guide for the external battery. Hope this helps.
Sarah Westberg - Antwoord
The "Battery 2" on my T480 does not load. Is Battery 2 the internal or the external battery?
Finn Hove - Antwoord
Battery1 is the internal
pride tafirei -
Battery 2 is the external battery.
Peter Falk - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 45
Afgelopen 7 dagen: 281
Afgelopen 30 dagen: 1,421
Altijd: 47,167
