LaCie Rugged USB-C Hard Drive Replacement
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
Push on one side of the drive, where the white plastic is. Which side does not matter.
6 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Thanks for confirming the T8 Torx security bit - I had to buy a set!
Andy, how are you. ?
Am facing the same issue, did fixed yours ?
Hello, I have this same drive. My hard drive is fine, the internal case that has the SATA to USB C connector isn’t working. Is there a replacement for the adapter/inner case & the adapter?
I have no idea of replacement of the LaCie internal case
But any generic USB C To SATA Adapter can be used - and very cheap on amazon too
Like in this link for example
Eoin -
