Ga door naar hoofdinhoud
LG Optimus Zone 3 Screen Replacement
Cooper Parnell
Cooper Parnell en 2 andere bijdragers
Voor het laatst geüpdatet op June 15, 2018
5 minuten
Gemiddeld
The screen of the LG Optimus Zone 3 is a common part that requires repair. The screen can often crack and instead of discarding the entire device, it is economical and environmentally friendly to just replace the plastic screen overtop of the display.
Wat je nodig hebt
Gereedschap
  1. LG Optimus Zone 3 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert fingernail into the slot on the back left side of the phone and pry open.
  2. LG Optimus Zone 3 Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove faulty battery.
    • The battery is missing from our device, however, it would be located in the section in-between the fingers.
  3. LG Optimus Zone 3 Screen Replacement, Screen: stap 3, afbeelding 1 van 1
    • Insert the plastic opening tool into the groove between the screen and the rest of the device. Work your way around the perimeter by sliding the opening tool around the edge, loosening the screen.
  4. LG Optimus Zone 3 Screen Replacement: stap 4, afbeelding 1 van 1
    • Once the screen is loosened, fully remove it from the device by peeling it away from the base of the phone.
Conclusie
Cooper Parnell
595 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 24
Altijd: 1,528
