Ga door naar hoofdinhoud
This is a simple teardown of the LG G watch R.
Wat je nodig hebt
Gereedschap
Deze demontage is geen reparatiehandleiding. Om je LG G Watch R te repareren, gebruik onze reparatiehandleidingen.
  1. LG G Watch R Teardown, Front and Back: stap 1, afbeelding 1 van 2 LG G Watch R Teardown, Front and Back: stap 1, afbeelding 2 van 2
    • LG G Watch R assembly.
  2. LG G Watch R Teardown, Removing the back cover: stap 2, afbeelding 1 van 2 LG G Watch R Teardown, Removing the back cover: stap 2, afbeelding 2 van 2
    • First remove the watch band using a small flat screw driver to compress the spring loaded pin.
    • Remove the four T4 torx screws (Green).
    • Carefully pry the base off using a thin flat screw driver
  3. LG G Watch R Teardown, Removing the Board: stap 3, afbeelding 1 van 2 LG G Watch R Teardown, Removing the Board: stap 3, afbeelding 2 van 2
    • Disconnect the four electrical connectors from the board
    • Orange - Battery connector
    • Blue - button and charging connector
    • Green - Backlight
    • Purple - O-LED Controller + Mic
    • Remove the three phillips screws securing the board down. Then lift the board off the base
  4. LG G Watch R Teardown, The Battery: stap 4, afbeelding 1 van 2 LG G Watch R Teardown, The Battery: stap 4, afbeelding 2 van 2
    • The battery is below the board.
    • The battery can easily be pried out using a small flat head screwdriver.
  5. LG G Watch R Teardown, Battery housing: stap 5, afbeelding 1 van 1
    • Using a small pliers and a small flat screwdriver the battery housing comes out easily.
  6. LG G Watch R Teardown, P-OLED Panel: stap 6, afbeelding 1 van 3 LG G Watch R Teardown, P-OLED Panel: stap 6, afbeelding 2 van 3 LG G Watch R Teardown, P-OLED Panel: stap 6, afbeelding 3 van 3
    • Pictures of the front and back of the 1.3" P-OLED.
    • The screen is glued in.
Dustin Richards
332 Reputatie
1 Handleiding geschreven
8Gids Commentaar
Is there a wifi antenna inside the LG G watch R?
Fernando Perez - Antwoord
Yes, there is a WiFi antenna inside the LG G Watch R, however WiFi functionality was only recently added to the G Watch R in a more recent update via Android Wear.
Mark Fortune -
Are there differences between the UK as US G Watch R?
James Kemble - Antwoord
Where could I find a battery for replacement?
Thanks in advance.
Fab - Antwoord
Any tips for what to check if the touchscreen turns on but is non-responsive ?
richard - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 22
Altijd: 20,450
