Ga door naar hoofdinhoud
HyperX Cloud III Connecting Cable Replacement
Wat je nodig hebt
  1. HyperX Cloud III Connecting Cable Replacement, Ear Cushion: stap 1, afbeelding 1 van 3 HyperX Cloud III Connecting Cable Replacement, Ear Cushion: stap 1, afbeelding 2 van 3 HyperX Cloud III Connecting Cable Replacement, Ear Cushion: stap 1, afbeelding 3 van 3
    • Pinch the side of one ear cushion with your thumb.
    • Slide it with your thumb to remove it completely from the outline.
    • Do the same on the other side of the headset if you want to replace both ear cushions.
    Vraag FixBot
    Voeg opmerking toe
  2. HyperX Cloud III Connecting Cable Replacement, Connecting Cable: stap 2, afbeelding 1 van 2 HyperX Cloud III Connecting Cable Replacement, Connecting Cable: stap 2, afbeelding 2 van 2
    • Use a Phillips #2 screwdriver to remove the four 9.4 mm-long screws securing the speaker plate to the earphone.
    • Use your fingers to pull and remove the black speaker plate.
    Vraag FixBot
    Voeg opmerking toe
  3. HyperX Cloud III Connecting Cable Replacement: stap 3, afbeelding 1 van 2 HyperX Cloud III Connecting Cable Replacement: stap 3, afbeelding 2 van 2
    • Use the Phillips #2 screwdriver to remove the 9.4 mm-long single screw securing the head of the connecting cable.
    Vraag FixBot
    Voeg opmerking toe
  4. HyperX Cloud III Connecting Cable Replacement: stap 4, afbeelding 1 van 2 HyperX Cloud III Connecting Cable Replacement: stap 4, afbeelding 2 van 2
    • Use the Phillips #2 screwdriver to remove the two 6.8 mm-long screws securing the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  5. HyperX Cloud III Connecting Cable Replacement: stap 5, afbeelding 1 van 2 HyperX Cloud III Connecting Cable Replacement: stap 5, afbeelding 2 van 2
    • Use tweezers to turn the motherboard backward, to desolder the connecting cables wires on this side.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow the steps instructions in reverse order.
Prior knowledge of soldering is required and working with wires is necessary.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 139
Altijd: 308
