How to create a macOS Time Machine backup
Inleiding
Ga naar stap 1Time Machine is data recovery tool built into macOS that is handy for backing up and restoring important files. This guide will show you how to enable Time Machine and save a backup of your Mac computer to another storage drive. To follow this guide, you will need an external storage drive—preferably one with more storage than the amount you are currently using on your internal drive.
Time Machine was first introduced with macOS 10.5 Leopard in 2007 and has been included in every version of the OS since. This guide will illustrate a backup using macOS 10.14 Mojave, but the process is similar across macOS versions.
Open the Time Machine preferences menu, located toward the bottom of your System Preferences pane.
Before you select a backup disk, use the Options menu to exclude any folders you don't want in your backup.
Use the + and – buttons to add or remove folders from the exclusion list.
If your machine is a laptop, you can check the first box to allow the computer to back up while it is using battery power (not plugged in).
Check the second box if you want a notification whenever Time Machine automatically deletes a backup to save space.
If your external drive isn't already connected to your computer, connect it now.
Click the Select Backup Disk button and select your external drive.
J’ai un disque dur externe ou déjà y’a des fichiers que j’ai transférés pour soulager le disque dur de mon Mac,es ce que timemachine vas effacer tous ces fichiers avant de sauvegarder les données que je vais y mettre sur le disque dur externe ?
If you want Time Machine to automatically make future backups, check the box on the left side of the settings pane labeled Back Up Automatically.
If you select Back Up Automatically, Time Machine will make backups once an hour, and keep backups as follows:
Hourly for 24 hours
Daily for the past month
Weekly for all previous months
Before the backup begins, Time Machine will configure the drive you have selected (if necessary), and prepare the files on your main drive to be backed up.
You may continue using your Mac while the backup is running. The backup will continue even if you close the Time Machine preferences window.
The first backup could take a significant amount of time, depending on how much of your data you chose to exclude and the speed of your backup drive. Subsequent backups will be shorter.
When the backup is finished, a Backup Complete notification will appear on the upper-right side of the screen.
Once your backup is finished, you’re done! Rest easy and know that you’ve got some protection, should you ever need it.
44 andere personen hebben deze handleiding voltooid.
Bereid je voor op toekomstige reparaties
Winkelen6Gids Commentaar
Bonjour, j’ai un disque dur occupé à hauteur de 247Go et la sauvegarde Time Machine s’est arrêtée à 40Go environ sans qu’il y ait de notifications dans le coin droit comme indiqué…
J’ai l’impression qu’il en manque donc comment être sûr que cela a bien fonctionné ?
TimeMachine will not backup the OS. You restore a TimeMachine backup to a drive AFTER installing a MacOS on the new drive. If you want to Restore an OLDER … (non-current) version of MacOS (like Mojave) you need to create a make a MacOS USB Installer ThumbDrive while the OS is still current.
How do you clone a failing Time Machine back up? This is a timely question.
Hallo
Wenn ich eine neue externe Festplatte/SSD als TimeMachine festlegen möchte für meinem kürzlich erworbenen iMac 2019/i9 unter MacOS Sonoma v.14.5, passiert immer wieder folgendes:
Die Festplatte/SSD wir zwangsläufig neu Formatiert in APFS, und während des Umwandeln in APFS kommt folgender Fehler: -69499.
Wenn ich die Festplatte/SSD bereits vorab in das Format APFS lösche, passiert dasselbe (immer während des Formatier Prozesses).
Der iMac kann ganz offensichtlich auch keine anderen APFS Medien mehr Mounten.
Wo kann das Problem liegen, bei anderen iMac`s habe ich dieses Problem nicht!? Es kann nicht an den Festplatten/SSD oder Kabel liegen!
Bin für jegliche Hilfe sehr Dankbar.
Tip`s bitte an: info@macstutz.ch
hi..can i back up data using a new SSD that later will replace the old one ? or i should use other external HD.
cause on other explanation “how to use internet Recovery to install macOs to a new SSD” it was mentioned that it should be formatted before i can install…
Achmad Iwan - Antwoord
