How to Remove the Rear Panel in your Whirlpool Refrigerator
Inleiding
Ga naar stap 1Use this guide to replace the rear panel in your Whirlpool Refrigerator. Removing the rear panel gives you access to the evaporator fan, coils, and other components.
This guide will work for most Whirlpool refrigerators. This guide is written with a model WRS315SDHW refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
Note: Some photos show the doors removed for clarity purposes. Removing them is not required and will not change the procedure.
Wat je nodig hebt
Gereedschap
Toon meer…
Remove the screw(s) securing the rear panel.
Loosen the screw securing the water hose enough for the rear panel to freely move.
Repair didn’t go as planned? Ask our Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
1 Guide Comment
How do you remove rear panel on the inside of whirpool french door refrigerator
