Ga door naar hoofdinhoud
How to Clean your iPhone's Lightning Port
Alex Diaz-Kokaisl
Alex Diaz-Kokaisl en 2 andere bijdragers
Voor het laatst geüpdatet op January 30, 2025
10 - 15 minuten
Eenvoudig
Use this guide to clean your iPhone's (generation 14 and below) charging port, a.k.a. the "Lightning port."
If your iPhone charges intermittently—or not at all—your charging port may be dirty, which prevents your charger from sitting correctly. Cleaning your charging port may fix this.
This guide uses tools that you might have around the house, but we also sell a Precision Cleaning Kit that includes some small brushes and picks to make your cleaning life easier.
Wat je nodig hebt
Gereedschap
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. How to Clean your iPhone's Lightning Port, Inspect your charging port: stap 1, afbeelding 1 van 3 How to Clean your iPhone's Lightning Port, Inspect your charging port: stap 1, afbeelding 2 van 3 How to Clean your iPhone's Lightning Port, Inspect your charging port: stap 1, afbeelding 3 van 3
    • Shine a flashlight into your charging port and inspect it for any large blockages.
    • A buildup of dust, grime, and lint inside the port can prevent the connector from fitting properly in the port.
    • Follow the guide normally to work your way through each procedure to thoroughly clean your port. Alternatively, click the links below to jump to a specific cleaning method:
    • Using a dust blower
    • Using a brush
    • Using isopropyl alcohol
    • Between cleanings, reinspect the charging port for any remaining blockages or missed spots.
  2. How to Clean your iPhone's Lightning Port, Blow air into the charging port: stap 2, afbeelding 1 van 2 How to Clean your iPhone's Lightning Port, Blow air into the charging port: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Dust Blower
    • Don't use your mouth to blow into your charging port, as the moisture from your breath can damage the contacts.
    • Point the tip of a dust blower at one corner of the charging port.
    • This gives room for any debris to eject out of the charging port.
    • Blow a few puffs of air into the charging port.
    • Plug in your iPhone to check if it charges and if the charger is fully seated.
    • If your iPhone isn't charging or seats properly, unplug it and repeat the blowing process.
    • If your iPhone still doesn't charge or sits properly after multiple repetitions, move to the next step.
  3. How to Clean your iPhone's Lightning Port, Brush your charging port: stap 3, afbeelding 1 van 3 How to Clean your iPhone's Lightning Port, Brush your charging port: stap 3, afbeelding 2 van 3 How to Clean your iPhone's Lightning Port, Brush your charging port: stap 3, afbeelding 3 van 3
    • Don't use any metal tools to clean the port, as you risk damaging the port.
    • Insert the head of a brush, like a dry toothbrush, into the charging port.
    • Gently turn the brush in small circles to break up any clumped debris.
    • Remove the brush and use a dust blower to blow out any debris.
    • If any debris is stuck, reinsert the brush and rotate it to let the hairs "scoop" out any debris.
    • Plug in your iPhone and check if it's charging. If it's still not charging, move on to the next step.
  4. How to Clean your iPhone's Lightning Port, Clean the charging port with isopropyl alcohol: stap 4, afbeelding 1 van 3 How to Clean your iPhone's Lightning Port, Clean the charging port with isopropyl alcohol: stap 4, afbeelding 2 van 3 How to Clean your iPhone's Lightning Port, Clean the charging port with isopropyl alcohol: stap 4, afbeelding 3 van 3
    • Follow this guide to make a custom cotton swab.
    • You can also use dental picks with barbed tips (non-flavored).
    • You can use a normal cotton swab, but most are too thick and have loose cotton that can snag on the pins.
    • Apply a few drops of highly-concentrated isopropyl alcohol (>90%) to the cotton.
    • Insert your tool into the charging port.
    • Don't force the tool into the charging port, as you risk bending the pins.
    • Slide the tool back and forth along the charging port to clean it.
    • Wait a few minutes for the isopropyl alcohol to evaporate before plugging in your iPhone and testing it.
  5. How to Clean your iPhone's Lightning Port, Test your iPhone: stap 5, afbeelding 1 van 1
    • Plug in your iPhone and check if it's charging:
    • If your iPhone is charging, congratulations!
    • If your iPhone isn't charging, repeat the isopropyl alcohol cleaning process.
    • If your iPhone still isn't charging after multiple cleaning attempts, and you confirmed with a flashlight that there's no debris, you may need to replace the charging port.
    • To replace your charging port, go to this page, find your iPhone's model, and follow the respective charging port guide for detailed instructions.
Conclusie
For other general electronics skills guides, click here.
14 andere personen hebben deze handleiding voltooid.
Alex Diaz-Kokaisl
162.011 Reputatie
769 handleidingen geschreven
iFixit Lid van iFixit
Staff
118 Leden
19.415 handleidingen geschreven
2 opmerkingen
The article on the Apple Support site says that compressed air should not be used: Cleaning your iPhone - Apple Support
WhiteDog - Antwoord
Fair enough! I have changed the text accordingly.
Alex Diaz-Kokaisl -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 132
Afgelopen 7 dagen: 973
Afgelopen 30 dagen: 4,970
Altijd: 75,920
