Ga door naar hoofdinhoud
How To Replace the Battery on a Conair Trimmer (GMT15NCS)
Nicholas Ellis
Nicholas Ellis en een andere bijdrager
Voor het laatst geüpdatet op July 16, 2024
15 - 20 minuten
Gemiddeld
The battery in the Conair Trimmer (GMT15NCS) can stop working or not hold a charge as well. This guide will show how to replace this battery to give the trimmer longer life.
Wat je nodig hebt
Onderdelen
Gereedschap
Toon meer…
iFixit krijgt commissie als je dingen koopt via deze links.
  1. How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: stap 1, afbeelding 1 van 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: stap 1, afbeelding 2 van 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS), Conair Trimmer (GMT15NCS) Battery Replacement: stap 1, afbeelding 3 van 3
    • Using a Phillips #0 screwdriver, remove the two screws holding the trimmer blade in place.
    • Hold down the trimmer blades to make it easier to remove the screws.
  2. How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 2, afbeelding 1 van 2 How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 2, afbeelding 2 van 2
    • Lift both of the trimmer blades off of the plastic guard.
  3. How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 3, afbeelding 1 van 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 3, afbeelding 2 van 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 3, afbeelding 3 van 3
    • Separate the plastic guard from the casing by using the metal spudger tool.
    • Pry up at the top of the plastic guard, NOT the bottom.
  4. How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 4, afbeelding 1 van 2 How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 4, afbeelding 2 van 2
    • Using a Phillips #000 screwdriver, remove the two screws inside the casing.
    • Tilt the trimmer to prevent the screws from falling into the casing.
  5. How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 5, afbeelding 1 van 1
    • Using a Phillips #000 screwdriver, remove the casing screw at the bottom of the trimmer.
    • Tilt the trimmer so gravity helps the screw fall out.
  6. How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 6, afbeelding 1 van 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 6, afbeelding 2 van 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 6, afbeelding 3 van 3
    • Fire Hazard: Be careful not to stick the metal spudger too deep when prying to avoid puncturing the battery.
    • Separate the casing at the seam using the metal spudger to release the clips.
    • Use a twisting or prying motion, in any direction, to separate the casing.
    • The same process may be needed on the other side's seam to release clips.
  7. How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 7, afbeelding 1 van 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 7, afbeelding 2 van 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 7, afbeelding 3 van 3
    • Remove the two screws holding the battery setup in place.
    • Take note of the position of the positive and negative terminals of the battery on the setup.
  8. How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 8, afbeelding 1 van 1
    • Lift the battery setup out of the casing.
    • Take note of how the battery setup lays in the casing.
  9. How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 9, afbeelding 1 van 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 9, afbeelding 2 van 3 How To Replace the Battery on a Conair Trimmer (GMT15NCS): stap 9, afbeelding 3 van 3
    • The soldering iron with be hot.
    • Using the soldering iron, desolder the battery at the connection to remove the battery from the setup.
    • Use iFixit's guide on Hoe moet je (de-)solderen? if you are not familiar using a soldering tool.
Conclusie
To reassemble your device, solder the new 2.4 V battery into the setup, and follow the instructions in reverse.
Nicholas Ellis
223 Reputatie
1 Handleiding geschreven
Één opmerking
Where can I buy the batery
Wenceslao Hernandez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 149
Altijd: 11,200
