Ga door naar hoofdinhoud
Hot Tools HPK12 Cord Replacement
Ben Miller
Ben Miller en 8 andere bijdragers
Voor het laatst geüpdatet op December 22, 2020
10 minuten
Eenvoudig
Use this guide to replace the electrical cord on the Hot Tools HPK12 Titanium Flat Iron.
The cord provides power to the flat iron. You will know if the device is working if the metal plates are hot when the cord is plugged in. Do not plug in a frayed or cracked cord.
Changing the electrical cord is a four-step process. Each step includes easy to follow instructions and a photo that demonstrates what you need to do.
Note that step three will require strength.
Wat je nodig hebt
iFixit krijgt commissie als je dingen koopt via deze links.
  1. Hot Tools HPK12 Cord Replacement, Cord: stap 1, afbeelding 1 van 1
    • Remove the two black 6mm screws.
  2. Hot Tools HPK12 Cord Replacement: stap 2, afbeelding 1 van 1
    • Slide the black O-ring out of its channel and pull it off the end of the flat iron.
  3. Hot Tools HPK12 Cord Replacement: stap 3, afbeelding 1 van 1
    • Separate the top and bottom pieces of the shell. It may require some force to break the seal.
  4. Hot Tools HPK12 Cord Replacement: stap 4, afbeelding 1 van 1
    • Remove the cord by pulling up and away from the bracket. You are now ready to replace the cord.
Conclusie
Ben Miller
288 Reputatie
1 Handleiding geschreven
IUPUI, Team 3-4, Baechle Fall 2016 Lid van IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
4 Leden
5 handleidingen geschreven
Één opmerking
Where can I get a replacement cord? You only show how to removed it but not how to fix it
Noe Salazar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 34
Altijd: 4,622
