Ga door naar hoofdinhoud
HP ProBook 455 G7 Battery Replacement
Wat je nodig hebt
    1. HP ProBook 455 G7 Battery Replacement, Lower Case: stap 1, afbeelding 1 van 1
      • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
      • Flip the laptop over so the lower case is facing up.
      • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
      Vraag FixBot
      Voeg opmerking toe
    2. HP ProBook 455 G7 Battery Replacement: stap 2, afbeelding 1 van 3 HP ProBook 455 G7 Battery Replacement: stap 2, afbeelding 2 van 3 HP ProBook 455 G7 Battery Replacement: stap 2, afbeelding 3 van 3
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Lift and remove the lower case.
      Vraag FixBot
      Voeg opmerking toe
    1. HP ProBook 455 G7 Battery Replacement, Battery: stap 3, afbeelding 1 van 3 HP ProBook 455 G7 Battery Replacement, Battery: stap 3, afbeelding 2 van 3 HP ProBook 455 G7 Battery Replacement, Battery: stap 3, afbeelding 3 van 3
      • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
      • Carefully lift the battery and remove it from the laptop.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Andiany Reynoso
253 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 1-6, Botvin Fall 2025 Lid van UMass Dartmouth, Team 1-6, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G6
3 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 28
Altijd: 199
