Ga door naar hoofdinhoud
HP ProBook 4530s WiFi Card Replacement
Drew Canada
Drew Canada en 3 andere bijdragers
Voor het laatst geüpdatet op June 2, 2023
1 - 5 minuten
Eenvoudig
Heeft betere plaatjes nodig
Door de gemeenschap gemaakte handleiding
This will teach you the easiest way I found to remove and replace the WiFi NIC in the ProBook 4530s.
Wat je nodig hebt
Gereedschap
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. HP ProBook 4530s WiFi Card Replacement, Introduction: stap 1, afbeelding 1 van 2 HP ProBook 4530s WiFi Card Replacement, Introduction: stap 1, afbeelding 2 van 2
    • Start by flipping over the laptop onto its back.
  2. HP ProBook 4530s WiFi Card Replacement, Battery Removal: stap 2, afbeelding 1 van 1
    • Push both switches inward. The battery should pop out a slight amount.
    • Pull out the battery.
  3. HP ProBook 4530s WiFi Card Replacement, Back Panel Removal: stap 3, afbeelding 1 van 1
    • Press on both of the battery switches then push on the back panel forward.
    • It should pop out slightly.
    • Lift and slide the panel off.
  4. HP ProBook 4530s WiFi Card Replacement, Connector Removal: stap 4, afbeelding 1 van 2 HP ProBook 4530s WiFi Card Replacement, Connector Removal: stap 4, afbeelding 2 van 2
    • Locate the WiFi card outlined in red.
    • The golden connectors will need to be popped off. They are marked in blue.
    • Be very careful. If these connectors break, you will have to buy entirely new wires and connectors.
    • Use a nail, a flat-head screwdriver, anything that will be able to pop off the connector gently.
  5. HP ProBook 4530s WiFi Card Replacement, Card Removal: stap 5, afbeelding 1 van 3 HP ProBook 4530s WiFi Card Replacement, Card Removal: stap 5, afbeelding 2 van 3 HP ProBook 4530s WiFi Card Replacement, Card Removal: stap 5, afbeelding 3 van 3
    • Remove the two screws that secure the card down.
    • The card should pop up at a 45 degree angle.
    • Pull the card straight out.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Drew Canada
1.433 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 28
Altijd: 3,902
