HP Pavilion dv9000 RAM Replacement
Inleiding
Ga naar stap 1After we have had a computer for a while, we notice that it starts to slow down. When a computer slows down, it could be caused by many issues. If the computer is an older model, the sluggish symptoms may be cured by upgrading the system's RAM. Finding and accessing the RAM can be difficult, but this guide ensures ease of access.
Wat je nodig hebt
Gereedschap
Turn the laptop over to expose the bottom side.
Locate the battery removal switch next to the battery compartment
Slide the switch all the way to the left to release the battery. The battery should pop up.
Lift the battery out.
Locate the middle plastic cover on the bottom of the laptop.
Unscrew the two 5mm screws using a Phillips #1 screwdriver. The screws should remain in the plastic cover.
Lift and remove the plastic cover.
Één andere persoon heeft deze handleiding voltooid.
