Ga door naar hoofdinhoud
HP Media Center 876x TV Tuner Card Replacement
Balakrishnan Pillai
Balakrishnan Pillai en 7 andere bijdragers
Voor het laatst geüpdatet op June 17, 2024
5 minuten
Eenvoudig
The HP Media Center 876x can utilize its TV tuner card to receive television service, enhancing its versatility.
Should you encounter difficulty receiving adequate service, consider replacing the TV tuner card.
A TV tuner card functions as a television tuner, enabling computers to receive television signals. Additionally, many TV tuners serve as video capture cards, enabling the recording of television programs onto a hard disk similar to a digital video recorder (DVR).
Refer to the HP Media Center 876x Troubleshooting Guide if you come across any other issues.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. HP Media Center 876x TV Tuner Card Replacement, Side Panel: stap 1, afbeelding 1 van 2 HP Media Center 876x TV Tuner Card Replacement, Side Panel: stap 1, afbeelding 2 van 2
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x TV Tuner Card Replacement: stap 2, afbeelding 1 van 3 HP Media Center 876x TV Tuner Card Replacement: stap 2, afbeelding 2 van 3 HP Media Center 876x TV Tuner Card Replacement: stap 2, afbeelding 3 van 3
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x TV Tuner Card Replacement, TV Tuner Card: stap 3, afbeelding 1 van 2 HP Media Center 876x TV Tuner Card Replacement, TV Tuner Card: stap 3, afbeelding 2 van 2
    • Identify the TV tuner card (distal from the cooling fan, in the lower-left corner of the tower).
    • Using a #0 Phillips head screwdriver, remove the one (6 mm) screw fastening the TV tuner card into its slot.
  4. HP Media Center 876x TV Tuner Card Replacement: stap 4, afbeelding 1 van 2 HP Media Center 876x TV Tuner Card Replacement: stap 4, afbeelding 2 van 2
    • Gently pull the card vertically out of its port.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Balakrishnan Pillai
1.003 Reputatie
8 handleidingen geschreven
Clemson, Team 6-1, Benson Spring 2014 Lid van Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 23
Altijd: 749
