Ga door naar hoofdinhoud
HP Envy x360 15m-cn0011dx Fan Replacement
Skylar Moore
Skylar Moore en 3 andere bijdragers
Voor het laatst geüpdatet op December 27, 2022
10 minuten
Eenvoudig
Betere introductie
This guide will demonstrate how to replace the fan and heatsink in the HP Envy x360 15m-cn0011dx laptop. The fan in this computer is connected to a heating pipe/heat sink. Be careful when removing the fan along with the heatsink as these parts are very fragile with a fair amount of force.
Make sure your device is fully powered off before attempting this guide.
Wat je nodig hebt
Gereedschap
  1. HP Envy x360 15m-cn0011dx Fan Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Flip the laptop over to the back side.
  2. HP Envy x360 15m-cn0011dx Fan Replacement: stap 2, afbeelding 1 van 2 HP Envy x360 15m-cn0011dx Fan Replacement: stap 2, afbeelding 2 van 2
    • Remove the six 5.6 mm screws from the back cover using a Phillips #00 screwdriver.
    • Remove the single 4.3 mm screw in the bottom middle section of the back cover using a T5 Torx screwdriver.
  3. HP Envy x360 15m-cn0011dx Fan Replacement: stap 3, afbeelding 1 van 1
    • Lift the back cover off the laptop.
  4. HP Envy x360 15m-cn0011dx Fan Replacement, Fan: stap 4, afbeelding 1 van 3 HP Envy x360 15m-cn0011dx Fan Replacement, Fan: stap 4, afbeelding 2 van 3 HP Envy x360 15m-cn0011dx Fan Replacement, Fan: stap 4, afbeelding 3 van 3
    • Loosen the four captive screws on the heat sink using a Phillips #00 screwdriver.
  5. HP Envy x360 15m-cn0011dx Fan Replacement: stap 5, afbeelding 1 van 3 HP Envy x360 15m-cn0011dx Fan Replacement: stap 5, afbeelding 2 van 3 HP Envy x360 15m-cn0011dx Fan Replacement: stap 5, afbeelding 3 van 3
    • Remove two 10 mm screws from the fan using a Phillips #00 screwdriver.
  6. HP Envy x360 15m-cn0011dx Fan Replacement: stap 6, afbeelding 1 van 1
    • Unplug the fan from the motherboard and lift the fan and heatsink out of the laptop.
Conclusie
Skylar Moore
715 Reputatie
5 handleidingen geschreven
Gateway, Team 1-4, Class Fall 2022 Lid van Gateway, Team 1-4, Class Fall 2022
GCC-CLASS-F22S1G4
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 228
