Ga door naar hoofdinhoud
HP Envy 4-1030us RAM Replacement
Christopher Luna
Christopher Luna en 4 andere bijdragers
Voor het laatst geüpdatet op January 4, 2018
5 minuten
Gemiddeld
In this guide we will be replacing the memory, also known as RAM chip. Whether you wish to upgrade your current memory, or want to replace a faulty chip, this guide will ensure that it will be done safely and effectively.
When working with electronic components, we recommend wearing an electrostatic wristband, it is possible for the static electricity present on you to discharge onto one of the components, wearing one of these wristbands and clipping it to a piece of metal will prevent this from happening.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. HP Envy 4-1030us RAM Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 HP Envy 4-1030us RAM Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
  2. HP Envy 4-1030us RAM Replacement: stap 2, afbeelding 1 van 2 HP Envy 4-1030us RAM Replacement: stap 2, afbeelding 2 van 2
    • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
    • Lift the bottom cover off of the system.
  3. HP Envy 4-1030us RAM Replacement, RAM: stap 3, afbeelding 1 van 1
    • Pull the two metal tabs on the left and right sides away from the chip.
  4. HP Envy 4-1030us RAM Replacement: stap 4, afbeelding 1 van 1
    • Grab the chip and slowly slide it upward and away from the computer.
Conclusie
Christopher Luna
700 Reputatie
6 handleidingen geschreven
USF Tampa, Team S1-G1, Thompson Fall 2017 Lid van USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 507
