Ga door naar hoofdinhoud
HP Chromebook 14-Q070NR Motherboard Replacement
Jose Hernandez
Jose Hernandez en 3 andere bijdragers
Voor het laatst geüpdatet op December 13, 2017
45 minuten
Gemiddeld
A motherboard is essentially the brain of a computer, it controls all the components in a computer to function properly without any errors. Use this guide to replace the motherboard of your device.
Wat je nodig hebt
Gereedschap
Toon meer…
  1. HP Chromebook 14-Q070NR Motherboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • At this point, the white caps that hide the top-most screws marked with red circles have been removed.
    • Using the Phillips #1 screwdriver, remove the (10) ten screws from the bottom of the device.
    • After removing the white caps covering the screws, use the Phillips #1 screwdriver to remove the (3) three screws indicated with red circles.
  2. HP Chromebook 14-Q070NR Motherboard Replacement: stap 2, afbeelding 1 van 3 HP Chromebook 14-Q070NR Motherboard Replacement: stap 2, afbeelding 2 van 3 HP Chromebook 14-Q070NR Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Open the laptop and place it upright. Remove the keyboard from the device using a plastic spudger or opening tool.
    • Carefully remove as there are ribbons attached to the keyboard that is connected to the components inside.
    • Gently lift the keyboard just enough to expose the ribbons.
  3. HP Chromebook 14-Q070NR Motherboard Replacement: stap 3, afbeelding 1 van 3 HP Chromebook 14-Q070NR Motherboard Replacement: stap 3, afbeelding 2 van 3 HP Chromebook 14-Q070NR Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Hold the keyboard up to remove the ribbons from the circuit board.
    • To remove each individual ribbon, grab the blue portion of each ribbon and pull it towards your direction until it is fully detached.
  4. HP Chromebook 14-Q070NR Motherboard Replacement: stap 4, afbeelding 1 van 3 HP Chromebook 14-Q070NR Motherboard Replacement: stap 4, afbeelding 2 van 3 HP Chromebook 14-Q070NR Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Once the ribbons are detached, remove the keyboard from the device.
  5. HP Chromebook 14-Q070NR Motherboard Replacement, Battery: stap 5, afbeelding 1 van 1
    • Using the Phillips #0 screwdriver, remove the (2) two screws at the bottom of the device.
    • Once removed, separate the screws from previous ones. They are different!
  6. HP Chromebook 14-Q070NR Motherboard Replacement: stap 6, afbeelding 1 van 2 HP Chromebook 14-Q070NR Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Remove the taped flat wire from the top of the battery.
    • Carefully pull away the connector from the top of the battery to the motherboard.
  7. HP Chromebook 14-Q070NR Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Carefully lift the battery and remove it from the device.
  8. HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: stap 8, afbeelding 1 van 3 HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: stap 8, afbeelding 2 van 3 HP Chromebook 14-Q070NR Motherboard Replacement, Motherboard: stap 8, afbeelding 3 van 3
    • Carefully remove the (3) three plastic strips attached to the motherboard.
  9. HP Chromebook 14-Q070NR Motherboard Replacement: stap 9, afbeelding 1 van 2 HP Chromebook 14-Q070NR Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Use the Phillips #1 screwdriver to remove the (5) five screws.
  10. HP Chromebook 14-Q070NR Motherboard Replacement: stap 10, afbeelding 1 van 2 HP Chromebook 14-Q070NR Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Use the blue plastic opening tool to disconnect the connectors. Remove the fan from the motherboard.
  11. HP Chromebook 14-Q070NR Motherboard Replacement: stap 11, afbeelding 1 van 2 HP Chromebook 14-Q070NR Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Gently lift while using the plastic opening tool to unhinge the motherboard from the computer in an upward pattern.
    • Be very careful not to detach the motherboard to quickly or forcefully since you could damage or break it.
Conclusie
Jose Hernandez
101 Reputatie
1 Handleiding geschreven
USF Tampa, Team S9-G5, Remmell Fall 2017 Lid van USF Tampa, Team S9-G5, Remmell Fall 2017
USFT-REMMELL-F17S9G5
5 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 289
